K23a1 Build
Old 12-14-2015, 02:13 PM
  #1081
KenB350z's Avatar
I'll look for the E70 today.
Old 12-14-2015, 02:22 PM
  #1082
Slow98teg's Avatar
You can ask the stations what blend is in the tanks. But most of the time they don't know. Easiest way is to test it with a kit you can buy.
Old 12-14-2015, 02:23 PM
  #1083
exist12's Avatar
you can also get an ethanol senor with the digital display
Old 12-14-2015, 02:25 PM
  #1084
exist12's Avatar
Originally Posted by Slow98teg
If you keep your GTR in a nice warm garage your statement is invalid lol. E85 vs e70 under 40 degrees there is a difference. Not tune related. Thats why they have a winter and summer blend.
I have been driving the gtr since I had the rdx down. even in 20 degree weather after sitting all day there was no issues starting with 1100 cc injectors
  #1085
KenB350z's Avatar
I will try RS Fuels first. I think they have a very large selection of different fuels.
Old 12-14-2015, 02:35 PM
  #1086
Slow98teg's Avatar
So within 4 seconds of cranking it starts up?
Old 12-14-2015, 03:07 PM
  #1087
exist12's Avatar
more like a second or 2
Old 12-14-2015, 08:37 PM
  #1088
KenB350z's Avatar
Call me crazy!?!?!
Old 12-14-2015, 08:41 PM
  #1089
FLETCH
TheWrench116's Avatar
Originally Posted by KenB350z
@ 8.5psi
i wish we could see the rpm VS speed the rpm is comparable to others when they do it vs speed its kind of useless. next time.
Old 12-14-2015, 08:42 PM
  #1090
FLETCH
do it!!!
  #1091
KenB350z's Avatar
Next time, I may have to take a trip up there!
Old 12-14-2015, 08:48 PM
  #1092
Slow98teg's Avatar
So why only 8.5psi? What's holding it back?
Old 12-14-2015, 08:56 PM
  #1093
KenB350z's Avatar
Oh sorry, we max out the boost values on the flashpro.
Old 12-14-2015, 09:01 PM
  #1094
Slow98teg's Avatar
One more issue for Hondata to fix I guess. Wrench and I have a couple things hondata needs to fix as well. Run pretty well though?
Old 12-14-2015, 09:03 PM
  #1095
KenB350z's Avatar
Currently yes, car loves the E85. Just need to crank up the boost!
Old 12-14-2015, 09:06 PM
  #1096
Slow98teg's Avatar
I'd guess around 16-18psi would put you close to 400hp.
Old 12-14-2015, 09:31 PM
  #1097
KenB350z's Avatar
Possibly
Old 12-14-2015, 10:37 PM
  #1098
FLETCH
captain MODest ^ in here
1 psi = 10 hp is the rule of thumb usually...
with this thing though who knows. it should crank out a decent number though especially on e70-85 whatever
KenB350z (12-14-2015)
Old 12-15-2015, 07:26 AM
  #1099
D-Rob's Avatar
You didn't adjust the actuator preload on the gate, or swap the actuator? The EFR can be manually controlled pretty easily with a 10mm wrench.
At 8psi, the OEM boost control solenoid shouldn't even be near hitting a maximum target, unless the wastegate actuator itself is adjusted so loose that it makes 2-3psi on gate pressure.
Don't bother with the supercharger, just turn the boost up! Keep it simple.
Old 12-15-2015, 10:38 AM
  #1100
KenB350z's Avatar
Come on D! Send me over a base map for Twin Charged engine. I know you got one somewhere. PM me the cost.
Old 12-15-2015, 10:44 AM
  #1101
D-Rob's Avatar
How 'bout you send me the current calibration on your car along with a datalog, and I get to the bottom of whatever is ailing you from making a bunch of power?
Old 12-15-2015, 04:15 PM
  #1102
KenB350z's Avatar
Check your email.
Old 12-15-2015, 05:36 PM
  #1103
KenB350z's Avatar
Damn, this is all we got.
Old 12-15-2015, 05:58 PM
  #1104
FLETCH
101 O_o
Old 12-15-2015, 06:01 PM
  #1105
FLETCH
keep in mind hes got a set of cams with spring and retainers that are good for more RPM then hes got it set to. let it SPIN some more.
BC stage 2 for iirc
Old 12-15-2015, 06:54 PM
  #1106
Slow98teg's Avatar
I should have added. Stations don't change anything to say it's 85% or 70%. You just have to test it. It get changed with starting winter and spring.
Old 12-15-2015, 07:00 PM
  #1107
KenB350z's Avatar
Could I run E100 during track season?
Old 12-15-2015, 07:26 PM
  #1108
Slow98teg's Avatar
If you get tuned for it yes. As long as you have room in your fuel system
Old 12-15-2015, 08:10 PM
  #1109
FLETCH
that's my issue. no room. once the adjustable fpr and return line are in though then it will probably run better all around. after the updated tune anyway.
Old 12-17-2015, 07:29 PM
  #1110
KenB350z's Avatar
New hope
Old 12-24-2015, 07:27 AM
  #1111
KenB350z's Avatar
Her belly!
Old 12-24-2015, 10:50 AM
  #1112
KenB350z's Avatar
Parking lot a little empty here on Christmas Eve...
Old 12-24-2015, 01:43 PM
  #1113
RDX10's Avatar
Speaking of which. Those jukes have a neat awd system similar to shawd, they can send 100% of rear power to one rear wheel, however they can't send more than 50% back there like we can. Also a turbo 1.6, I was stongly considering one, I actually don't hate the styling. But the cvt killed it for me.
Old 12-24-2015, 08:50 PM
  #1114
KenB350z's Avatar
Haha! I told that co-worker that if I had his juke, I would seriously consider the GTR swap!
Old 12-25-2015, 04:17 AM
  #1115
RDX10's Avatar
Oh god, the things I would do in a juke R. Just so much beautiful 3.8TT goodness! Sadly, we got nearly half the displacement, 2/3 the cylinders, half the turbos and +200 pounds.....and you ask why I am bitter haha
Old 12-28-2015, 12:52 AM
  #1116
FLETCH
so swap in a 3.7 with a set of blouch RDX upgrade twins and the rear diff from a MDX be right around 650-800 TQ 600 hp would be braking axles left and right might lunch the transmission too.
Old 12-28-2015, 03:23 AM
  #1117
RDX10's Avatar
I like the way you think! I just really don't think a honda transmission could handle anything more than mild abuse. But seriously though, would be so sick if honda was ballsy enough to just mess around with a twin turbo mdx and rdx. Like nissan was ballsy and put the gtr engine into the juke, these kind of over the top things put car makers on the map. No chance the puny rdx axles could handle the abuse, especially the thin crappy rear axles. I even doubt the mdx diff could hold.
Old 12-28-2015, 09:52 AM
  #1118
FLETCH
keep in mind the stock engine is rated at 265 tq at the crank and im putting down 370+ to the ground... so keep in mind that mine is still living and if we do the math
to the wheels x drive line loss correction of 20% = est crank TQ
370 x 1.20 =444 TQ
at the crank which is VERY conservative.
keep in mind its not hp that kills stuff its TQ
Old 12-28-2015, 11:14 AM
  #1119
Tomtwtwtw's Avatar
Her belly!
Just curious, why the kink in the exhaust right there?
Old 12-29-2015, 02:10 PM
  #1120
KenB350z's Avatar
Because it was cheap, unlike the CF Driveshaft next to it.
Quick Reply: K23a1 Build
