K23a1 Build
OEM Honda RBC intake manifold (PRL Motorsport's port matched manifold to throttle body 70mm)
OEM Acura ZDX 70mm throttle body (bolts right up to RDX throttle body connector)
PRL throttle body 70mm adapter
I had to cut the water neck off myself, wasn't to hard though
^ yes it does, per hondata
im still curious on what the advantage of a RBC intake is over ours.. i think the runners are close to the same length.. and i dont think the inside diameter of the tubes are that much bigger.. i would like to know more specifics about the 2 i may just op for a zdx throttle body and call it good myself
Haha, well the runners are much wider and the plenum is like night and day difference. Combined with a 70mm bore will be killer with force induction. Trust me, it is a better flowing manifold.
also you didnt answer my other question.. where you find the piping for the re route for the BOV?
I'm not sure I will have any comparison's with the two manifold, I should have put it on the dyno before all this. It's just a 1.75" S pipe from ebay with coupler to connect each end.
I'm still looking for a company that will upgrade my stock turbo, but haven't found any yet. Anybody know of companies that repair and upgrade stock turbos?
The following 2 users liked this post by KenB350z:
bluecarbonfiber (06-15-2014),
DRR98 (06-24-2014)
The following 2 users liked this post by dresx:
BigHatch (06-15-2014),
TheWrench116 (08-04-2014)
jojo32m (05-30-2023)
how much was it to do this? and how much more hp can the 18t put out?
DRR98 (06-24-2014)
bluecarbonfiber (06-17-2014)
Holy SH@#! Ok, after I got the ecu back from Honata the reflash was good, but it would only pull for the first 4k rpm then tapper off the boost.... Oh, not now these thing pulls hard as F$%#!! I took it out this morning, and had to let off because I was going way to fast!! Can't wait to put the cams in, get tuned and take it to the track. I'm sure the "World Record white RDX" on YouTube will be crushed! Stay tuned.
DRR98 (06-24-2014),
noodle4rdx (08-07-2014)
