E85
Old Jul 9, 2015 | 06:37 PM
Furio8685's Avatar
E85
I was just curious if anyone has converted to e 85? And if so with what kind of results... Power and fuel economy
Old Jul 9, 2015 | 09:24 PM
KenB350z's Avatar
Soon, when the car is back on the ground and I empty the 93, then it's on the E85.
Old Jul 10, 2015 | 10:31 AM
Tomtwtwtw's Avatar
E85 should work miracles in this engine. I can't want to see that...what size injectors did you end up going with Ken?
Old Jul 10, 2015 | 10:53 AM
KenB350z's Avatar
I have 800cc may bump up soon.
Old Jul 10, 2015 | 01:49 PM
Furio8685's Avatar
What kind of tune do u need for it seeing as it has less energy? Are you going to get a dyno tune right afterwords or are you being tuned by vit
Old Jul 10, 2015 | 01:52 PM
KenB350z's Avatar
I'll be turned by someone local for the E85, you will also need fuel components that are compatible with E85. Like fuel injectors, fuel filter, etc.
Old Jul 14, 2015 | 08:49 PM
779civic's Avatar
I have been running e85 for the past two years now. I started with a 50/50 mix with stock injectors. Now im running a dw260 pump and id1000cc injectors. The rest is still stock.
Old Jul 15, 2015 | 01:48 AM
KenB350z's Avatar
When did Deatschwerks make a DW260? I had a DW200 and it didn't fit.
Old Jul 15, 2015 | 07:42 AM
779civic's Avatar
It's a dw65c 265lph
Old Jul 15, 2015 | 11:21 AM
KenB350z's Avatar
Ok, was gonna say.... I put mine in exactly one year ago. https://acurazine.com/forums/perform...-912724/page7/
Old Jul 15, 2015 | 06:43 PM
779civic's Avatar
I got mine last September and been running full e85 since. Haven't had any issues so far. The ecu likes the e85 it will hold more boost vs 91oct. From my experience.
Old Jul 15, 2015 | 07:41 PM
KenB350z's Avatar
Cool
Old Jul 16, 2015 | 04:37 PM
Furio8685's Avatar
What kinda fuel mileage you get running to e 85
Old Jul 16, 2015 | 10:18 PM
KenB350z's Avatar
Currently not running it. I will when my setup is done.
Old Jul 17, 2015 | 07:38 AM
TheWrench116's Avatar
FLETCH
might need some 1xxx cc injectors for that.
Old Jul 17, 2015 | 08:12 AM
KenB350z's Avatar
For sure, I will be testing out the new DW300c fuel pump and those new DW Dv2's. I happened to be at a wedding and was seated with Vinh Chau the fuel pump production supervisor and he told me all about it. He said the new Dv2's are alot better and that pump is amazing. Might get some core credit.
Old Jul 19, 2015 | 08:50 AM
779civic's Avatar
im getting 13-15mpg depending on how I drive.
Old Jul 20, 2015 | 06:50 AM
FLETCH
ouch ^ that's painful I know we don't mod for mileage but I'm happy that I'm getting a solid 20 MPG in mixed hard driving and even better when I keep my foot out of it. also keep in mind that I live in between 3 mountains and flat doesn't exist in my area. if I could stand to do a highway trip and keep my speeds closer to the speed limit I could probably get around 26-28.?.
Old Jul 20, 2015 | 08:39 AM
KenB350z's Avatar
One quick note: if you don't drive your car alot, then E85 may not be for you. It is highly corrosive and blocks (gunks) up there injectors. The injector supervisor at DW was showing me old customers stuff. I'm a bit hesitant at this point, but I do believe that I will put some miles it, so it could be for me.
Old Jul 20, 2015 | 06:40 PM
Furio8685's Avatar
If I can only loose 25% mpg it would be cost effective for me to run. I bet with a tune you could get a little more. In Illinois its more than a dollar cheaper than 93. E 85 is 2.09 right now where premium is like 3.19 or so. How much more power should you expect to gain vs 93? 10% or so... I drive a lot interesting conundrum
Old Jul 21, 2015 | 10:43 AM
Tomtwtwtw's Avatar
25-30% fuel economy hit is about par for the course since E85 has a much lower energy density that regular gas. Power gain is based on your tuner and your set up, but the potential is there. 10% should be doable...a good chuck of the power comes from more aggressive spark timing, not just cranking boost.
Old Aug 29, 2015 | 07:09 AM
D-Rob's Avatar
There should be fairly good gains with E85. Especially if you're using the stock ECU's knock control/ignition advance logic.
I will be testing E85 on "Slow98teg's" RDX very shortly. I'm sure he'll post about it.
gavriil
Nov 12, 2013 10:57 AM
assclown
53
Dec 2, 2010 01:06 PM
Motorsports News
Sep 1, 2006 08:41 AM
zhouz
Jun 2, 2006 07:34 AM
