K23a1 Build
Old Jul 15, 2014 | 09:21 AM
  #241
TheWrench116's Avatar
FLETCH
like!!!!
Old Jul 15, 2014 | 09:27 AM
  #242
KenB350z's Avatar
Ok, the DW65c is a perfect match.
Old Jul 15, 2014 | 09:31 AM
  #243
FLETCH
how much will it support? power wise?
Old Jul 15, 2014 | 09:42 AM
  #244
KenB350z's Avatar
I don't think you can say power wise unless you have dyno charts. It supports the 800cc injector. Rob at Humble Performance said a guy made 400hp on just the DW200. But, we won't make enough power to even make this pump sweat.
Old Jul 15, 2014 | 09:45 AM
  #245
bluecarbonfiber's Avatar
WTF?
*Pounding fork and spoon on table* DYNO DYNO DYNO DYNO DYNO!!
Old Jul 15, 2014 | 10:09 AM
  #246
FLETCH
ah thankya thank ya very much
Old Jul 15, 2014 | 11:46 AM
  #247
KenB350z's Avatar
No problem. I have a question, what adapter do we need to run aftermarket BOV? Mazda speed3?
Old Jul 15, 2014 | 12:07 PM
  #248
FLETCH
I could make you an adapter plate if you send me the bov you want to use if you do a really good job marking your pipe I could weld that up as well. its up to you. although I thought I read that our stuff was good to 20 psi
Old Jul 15, 2014 | 12:57 PM
  #249
WTF?
dont need an adapter if you get the bov for a first gen mazda speed 3 just make sure its a recirculating
Old Jul 15, 2014 | 01:05 PM
  #250
KenB350z's Avatar
Oh
Old Jul 15, 2014 | 01:24 PM
  #251
FLETCH
? why change it?
Old Jul 15, 2014 | 06:26 PM
  #252
dresx's Avatar
Originally Posted by TheWrench116
? why change it?
Yeah x2
Old Jul 15, 2014 | 06:33 PM
  #253
KenB350z's Avatar
? why change it?
Just in case of a BOV leak when tuning.
Old Jul 15, 2014 | 06:38 PM
  #254
KenB350z's Avatar
The install was easy and straight forward. All you do is removed the right rear seat and pill the carpet back.
Old Jul 15, 2014 | 06:46 PM
  #255
KenB350z's Avatar
This reminds me of high school. Remember, removing the rear seats added 50hp....
Old Jul 16, 2014 | 09:48 AM
  #256
WTF?
how dirty was the stock fuel filter?
Old Jul 16, 2014 | 10:09 AM
  #257
FLETCH
X2^
Old Jul 16, 2014 | 11:23 AM
  #258
BigHatch's Avatar
not an SUV ...a Big Hatch
man... I keep checking in at odd hours hoping to hear news of even a tuning appt.!!
Old Jul 16, 2014 | 12:59 PM
  #259
KenB350z's Avatar
The filter sock really wasn't that dirty.
Old Jul 16, 2014 | 01:01 PM
  #260
KenB350z's Avatar
It's coming. real soon!
Old Jul 16, 2014 | 02:26 PM
  #261
KenB350z's Avatar
Air temperature sensor just came in.
Old Jul 16, 2014 | 07:41 PM
  #262
FLETCH
Does out air temp sensor have a bottom and top limit? Like it won't red below 75 and or above 150?
Old Jul 16, 2014 | 10:32 PM
  #263
KenB350z's Avatar
It's, for the new charge pipe I'm going to have welded.
Old Jul 17, 2014 | 12:13 AM
  #264
ivan_baez's Avatar
ken,
hi, your project looks awesome. I have a couple of questions:
have you been able to upgrade your turbo yet?
is the cam part number 63451T-2 (Acura K20A RSX DOHC Turbo Camshaft)?
what kind of CELs have you got and what part install caused it?. I ask because I am trying to beef up my RDX without going all out race or getting a bunch of CELs or custom tuning.
I have tried cams in other vehicles and seems to be one of the best bang for the buck mods to provide real HP gains. I had a GT2560R turbo fitted with a GT3071 compressor wheel and it also provided good gains (~20HP at the wheels).
currently I have the std hondata reflash, methanol injection and CAI. Do you think the cams would need the dual spring set if you are only going up to 7000 RPM?
thanks in advance for your feedback.
Old Jul 17, 2014 | 12:55 AM
  #265
KenB350z's Avatar
Originally Posted by ivan_baez
ken,
I have not upgraded the turbo yet. Are you talking about the stock cam or the BC stage 2 turbo cam I installed?
The only CEL I got was when I put the 3" exhaust on, but the rear O2 was turned off via flashpro, so currently I have no CEL.
The RBC intake manifold and ZDX throttle body was probably my best bang for the buck, I think. But, I'm still going though...
Old Jul 17, 2014 | 09:33 AM
  #266
420Coupe's Avatar
ken,
any change in cam requires tuning....
Old Jul 17, 2014 | 10:17 AM
  #267
WTF?
ken,
you would need to upgrade to flashpro to do cams.. and yes you need dual spring for the valves.. it even recommends it on the website.
Old Jul 17, 2014 | 12:25 PM
  #268
dresx's Avatar
I haven't seen any flow tests for the RDX manifold. Would you be able to test both manifolds? The RDX one looks like it might offer better distribution to the cylinders.
Old Jul 17, 2014 | 07:47 PM
  #269
KenB350z's Avatar
Yes, for stock intake volume. I plan on making some power and you can't make power with a D-series sized intake manifold. Most of the stock bolt on parts for the K23a1 are sized for emission reasons. Small potatoes....
Old Jul 17, 2014 | 09:05 PM
  #270
dresx's Avatar
Oh, I was thinking along the lines of the IPS manifold. The design is like the RDXs. Short runners, shaped plenum, and a convenient place for the throttle body. They flow very well and make power. They cost quite a bit too. I thought it was worth looking into, but you're probably right.
Old Jul 17, 2014 | 09:23 PM
  #271
KenB350z's Avatar
I don't think that intake manifold will work, because it can not be flipped. The throttle body opening is facing down. Now, Xcessive manufacturing makes a manifold that I looked in to. It can be flipped, so the throttle body opening is facing up. But it would probably be to big for our setup. The RBC is "one" of the best flowing intake manifold along side the RRC. I think the RBC will do well with our setup.
Old Jul 18, 2014 | 04:53 AM
  #272
KenB350z's Avatar
I wonder what kind of adapter they used for the tranny! K23a1 sway..
Old Jul 18, 2014 | 10:01 AM
  #273
WTF?
ya thats interesting.. no intercooler either..
  #274
WTF?
when is tuning day?
Old Jul 18, 2014 | 12:18 PM
  #275
WTF?
Ken you find out if a 05-08 RL driveshaft the same size as our vehicles? be nice to replace it with a stronger and lighter part
Old Jul 18, 2014 | 08:01 PM
  #276
KenB350z's Avatar
when is tuning day?
Coming soon, still waiting to get my charge pipe made.
Old Jul 18, 2014 | 08:07 PM
  #277
KenB350z's Avatar
Sorry, the guy hasn't driven his RL in a while. I will have to push him in to bring it monday and hopefully we can get some measurements of both RDX and RL propeller shafts. RL part #40100-SJA-E02 $1566.75
Old Jul 18, 2014 | 09:50 PM
  #278
WTF?
you can find used ones for around 250.. dont need new =)
Old Jul 19, 2014 | 12:11 AM
  #279
KenB350z's Avatar
I hear ya. The stock RDX shaft was around 400.00, so the RL's must be a better quality piece for that OEM price.
Old Jul 19, 2014 | 08:00 PM
  #280
KenB350z's Avatar
Have to change my vtec point. I'm tired of the 2500 vtec engagement. With the cams the vtec is more audible and it is getting annoying at every stop ( mmMMBbbaahhh.) Flashpro owners, what do you have your vtec point set at or what is stock engagement set at?
