downpipe install
Old Mar 26, 2015 | 07:20 AM
rdxchris710's Avatar
RDX faN BoY
downpipe install
This thing sucks ass to install. Thank you to a few people on here for helping. Looks like the half shaft is coming out today. What else do I need to unbolt besides the ball joint. I want to remove the bare min to get he stock primary cat out the wheel well.
Old Mar 26, 2015 | 08:25 AM
KenB350z's Avatar
I didn't have to take anything off, "SNAKE" it in from the top.
Old Mar 26, 2015 | 09:32 AM
RDX faN BoY
No way in hell hahah Im going to take the intercooler off. I need to just get the primary cat out as it is floating around on there. I just it off the turbo but I can not get the Axel to separate from the half shaft tho. I am going to pull the intercooler and try one more time to get it out from the top.
Old Mar 26, 2015 | 09:38 AM
bluecarbonfiber's Avatar
WTF?
the intercooler is pretty easy to get on and off.. but snaking it up through the top is the best option ive seen people do through the past
KenB350z's Avatar
Haha, man. Wish I could be there to help. But, I just went from the top.
Old Mar 26, 2015 | 10:40 AM
csargemg's Avatar
Yeah, we just didn't have the room to work with to get the cat out. Wheel well was the way to go for us.
Old Mar 26, 2015 | 11:17 AM
JHRdx2011's Avatar
3rd Gear
Yeah I got mine installed a month ago, I went to another Acurazine member in my area and he helped me installed the parts. We were able to reached the first cat after getting the intercooler off and through the top. Somehow we managed to get the first cat off without taking off the shaft... But to do that we needed to take those big heat shields off first and then squeezed everything else through successfully.
Old Mar 26, 2015 | 12:03 PM
csargemg's Avatar
Oh you took off the heat shields while the cat was still in there?
That certainly might do it.
Old Mar 26, 2015 | 01:06 PM
JHRdx2011's Avatar
3rd Gear
Yeah I didn't have to remove the shaft, just a bit of hard work squeezing them out...
Old Mar 26, 2015 | 01:15 PM
RDX faN BoY
i got it out! I had to cut everything up to the inlet of the cat and got it out the top. I separated the axel but did not need to do it. Ahh at least the install will be soooooo much easier. Ill have a video of open downpipe haha need to get it up on the ramps to install the 2nd part of it. btw rich at rv-6 is awesome.. i lost the directions just wanted to see if i missed a step and he sent them right to my email and we talked on the phone. a+ in my book. Now if we could get them to make a 3" cat back )
Old Mar 26, 2015 | 03:13 PM
csargemg's Avatar
congrats! The install is pretty easy. Be very careful on that secondary O2 sensor position and follow the directions very carefully. I'm still not throwing a light myself...
Old Mar 27, 2015 | 07:50 AM
RDX faN BoY
I just cut the wires on the secondary o2. I was pissed when it came time to unhook haha. I disabled it In flashpro so no cel. Broke the passenger side wheel sensor by not supporting the knuckle when I took the Axel out.. No biggie $24 from acura. I would disable the secondary and you will never need to mess with it again. About 12-13:1 Afr from my 11.6 so it leaned out a little bit.
Old Mar 27, 2015 | 11:32 AM
csargemg's Avatar
So, I have all my readiness monitors passed except for EVAP, and no pending codes. I've got my AFRs down to 12.2-12.3 with a slight cut to boost with a target of 11.6 as well - is that acceptable to run with? Should I target richer?
Old Mar 27, 2015 | 12:57 PM
Tomtwtwtw's Avatar
I'm not sure what the ideal AFR is for these cars, but if you're not knocking or pulling timing, you should at least be safe.
Old Mar 22, 2016 | 10:06 PM
RDX007's Avatar
8th Gear
Hello KenB350z,
How did you "SNAKE" your Downpipe from the top and not have to remove any parts?
I have(2007 RDX/Tech) A ATLP Exhaust and soon will have the Rv6 High Flow Downpipe. I want to install both in one shot. Any advice/photos would be greatly appreciated! Thanks!
Old Mar 23, 2016 | 11:05 AM
hues10's Avatar
Yes, Pictures and how-to would be great. Is it doable by a novice who can take apart things like nuts and bolts, but when you start talking cutting CAT's and pipes and such, that may be a little too much for me to want to handle. RDX is now five years old and out of the initial CPO warranty. Now, just powertrain left for two more years. Still a joy to drive once a week.
Old Mar 24, 2016 | 08:22 PM
KenB350z's Avatar
I don't think I took as many pictures as I do now. But, you can just wrap a cloth around it and get it through the top.
Old May 14, 2016 | 10:15 PM
RDX007's Avatar
8th Gear
What did you remove to install "snake" the DP from the top? TMIC and what else? I have the catted DP, did you have both pieces connected when you "snaked" it from the top?, obviously you removed the old DP first. Were you able to remove the heatshield and all the bolts from the top or did you have to do some work from the underside of the car? Wrapping the DP must mean you really have to force it in place from the top. Thanks for any info you can supply.
Old May 22, 2016 | 10:18 AM
Haré romel's Avatar
Hi, I had to remove passenger drive shaft and snaked... was difficult.
Old Jul 22, 2016 | 02:14 PM
spooled-up's Avatar
5th Gear
if my emissions light is on already, will it stay on after i install the rv6 downpipe cat delete. I'm hoping my problem is just the old cats and that the emissions code is causing the tranny and AWD codes to go off too.
Old Jul 28, 2016 | 08:41 PM
tili199's Avatar
hey bud where did you get your downpipe from? anyone else have any recommendation on headers & a cat that wont break the bank?
Old Jul 29, 2016 | 10:07 AM
TheWrench116's Avatar
FLETCH
RV-6 is your only option. but i do know of a guy that's getting rid of his.
Old Aug 18, 2016 | 08:55 AM
spooled-up's Avatar
5th Gear
Rv6 downpipe for sale
Anybody interested in a rv6 cat-delete downpipe for 1st Gen rdx?
cycdaniel
Dec 17, 2019 10:58 AM
space_boy
ILX
51
Aug 15, 2017 12:06 PM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
pistacio
Sep 26, 2015 09:45 AM
TxRzrBk
Sep 17, 2015 01:07 PM
