Headlights
Originally Posted by acurardx
Do you guys know if we can set the highlights auto off when turn off the key ? (My Camry was able to do that)
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
2016 MDX Adv/SHAWD
If you leave your lights on, but lock the car with the key fab the lights will timer off, i think its like 30sec. When you open your car door to go back in it, the headlights will go on again. Just got mine today and have been checking on every little detail.
![Yum](https://acurazine.com/forums/images/smilies/yum.gif)
Base RDX - Carbon Pearl
Headhlight
You mean just ignore the beeping warning sound when the door is open with the light on, and it will be turn the headlights off in 30 seconds ?
yes i tried it, the lighter goes off itself in 30 something sec and turn back on when i open the door.
With tech package you can set it to zero, 15, 30, or 60 seconds. Default from factory is 15 seconds. I changed mine to zero so the lights turn off when I close the doors.
On the base model, it is set on 15 seconds and you can't change it I believe.
if you turn the car off and remove the key and do not open a door, the lights will shut off after 10 minutes automatically.
Missin my TSX =(
regardless of wat setting its on, tech package or not... it will turn off automatically... eventually.... but with tech package... u can pick the time it waits to turn off
AmplifiedDetails
09-24-2015 02:55 PM
