Headlights
Old Oct 11, 2006 | 01:17 PM
acurardx's Avatar
Base RDX - Carbon Pearl
Headlights
Do you guys know if we can set the highlights auto off when turn off the key ? (My Camry was able to do that)
Old Oct 11, 2006 | 01:30 PM
schuchmn's Avatar
Dennis
So did my last two cars -- I never had to turn the lights either on or off. And I keep forgetting that the Acura doesn't do that. Good thing it warns me if I leave the car with the lights on. Now if only it would warn me when it's dark and the lights are off.
Old Oct 11, 2006 | 02:35 PM
neo1738's Avatar
2016 MDX Adv/SHAWD
If you leave your lights on, but lock the car with the key fab the lights will timer off, i think its like 30sec. When you open your car door to go back in it, the headlights will go on again. Just got mine today and have been checking on every little detail.
Old Oct 11, 2006 | 02:50 PM
acurardx's Avatar
Headhlight
You mean just ignore the beeping warning sound when the door is open with the light on, and it will be turn the headlights off in 30 seconds ?
Old Oct 11, 2006 | 03:14 PM
jaobrien6's Avatar
Yup, that's exactly right. The TSX works that way, too. I'm guessing most (all?) of the newer acura's do, probably.
Old Oct 11, 2006 | 03:37 PM
buckeyesi's Avatar
From what I remember any Acura that has navi lets you customize this feature.
Old Oct 11, 2006 | 03:52 PM
ravemother's Avatar
yes i tried it, the lighter goes off itself in 30 something sec and turn back on when i open the door.
Old Oct 11, 2006 | 05:45 PM
sasair's Avatar
With tech package you can set it to zero, 15, 30, or 60 seconds. Default from factory is 15 seconds. I changed mine to zero so the lights turn off when I close the doors.
On the base model, it is set on 15 seconds and you can't change it I believe.
if you turn the car off and remove the key and do not open a door, the lights will shut off after 10 minutes automatically.
Old Oct 11, 2006 | 11:40 PM
chyllintsx's Avatar
Missin my TSX =(
regardless of wat setting its on, tech package or not... it will turn off automatically... eventually.... but with tech package... u can pick the time it waits to turn off
hashbrown
Feb 18, 2022 11:20 AM
Mr.Tea
Oct 2, 2015 10:32 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
