Secondary Oxygen Sensor Heater Circuit
Old Jan 30, 2009 | 09:04 AM
chriscdeleon's Avatar
4th Gear
Unhappy Secondary Oxygen Sensor Heater Circuit
I just had the oygen sensor replaced on my 1997 Acura CL 2.2 because it got a CEL code of 65 which which told me it was "
Secondary Oxygen Sensor Heater Circuit". After i did the check engine light still came back on for the same issue. I even disconnected the battery for a few minutes to clear the CEL but cam back on. Anyone can assit me on this, PLEASE!!! HELP!
Last edited by chriscdeleon; Jan 30, 2009 at 09:05 AM. Reason: forgot to state what kind of car
Old Jan 30, 2009 | 09:15 AM
Yurhomieblaze's Avatar
cool breeze
proable cause-open or short in secondary o2 heater circuit
i don't want to type the whole flow chart on how to diagnose the o2 sensor
go here (link deleted)
download the service manual for a 97 accord, look up under pgm-fi section (i think pg 11-71) and go through the whole procedure to diagnose your o2 short/open, you will need a voltmeter for this
Edit by Admin Ron A: I had to delete the link because we cannot allow links to copyrighted material to be posted in the forum.
Old Jan 30, 2009 | 10:56 AM
Mach30SiR's Avatar
Bagel Bomber
I wonder if RonA has ever seen the light of day.
Old Jan 30, 2009 | 11:13 AM
4th Gear
Yurhomieblaze,
can you send me the link to chriscdeleon@gmail.com
Old Jan 30, 2009 | 11:29 AM
cool breeze
emailed
i know the mods just doing his mods duty to uphold the rule, but the rule stinks
Old Jan 30, 2009 | 11:31 AM
4th Gear
Thanks Yurhomieblaze. It was replaced my a mechanic using a Denso brand rear oxygen sensor. Could using an non-Acura brand cause the problem. The mechanic stated that maybe it could be the catalytic converter or maybe some electrical. Please advise on this if any of this is true.
Old Jan 30, 2009 | 11:38 AM
cool breeze
proably not the senosr unless its a gross mistake on the mechanics side but most likely electrical
i'd get the manual and a voltmeter and follow the step by step intstructions, it will determin what wires open/short
closer look at my service manual say it could also be the ecu but you have to go though the steps to see if its the sensor, the wires or ecu.
Old Jan 30, 2009 | 12:13 PM
4th Gear
where is the ecu located?
Old Jan 30, 2009 | 01:30 PM
iansanderson's Avatar
'99 2.3 CL
Yes, using an aftermarket Denso can cause the light to come back on. I have heard this before from several people.
I'm not sure who Honda uses for the O2's, but I think its NGK or TEK. You might have to get one from the dealer or online to save some $$.
Mike Pilipenko
Mar 26, 2024 09:21 PM
Jamus22
Jun 11, 2023 10:08 AM
RobbDizzle
Oct 15, 2015 11:16 AM
07Acuradude
Sep 29, 2015 03:01 PM
thegipper
Sep 28, 2015 01:01 PM
