RPM UP/DOWN help
Old Jun 1, 2010 | 09:30 PM
john6699's Avatar
RPM UP/DOWN help
98 CL 3.0 parked not running for over a year. Ran the engine until most of the gas was out changed the fuel filter put injector cleaner in and filled tank up.
Now the rpm go up/down in park and while in drive rpm are higher then before.
Could this be a sensor or gas and suggestions thanks
Old Jun 1, 2010 | 10:59 PM
salogCL's Avatar
does it idle rough?
Old Jun 1, 2010 | 11:31 PM
john6699's Avatar
Not that I can tell just up/down in park and in drive high then normal
Old Jun 2, 2010 | 12:04 AM
asianspec's Avatar
this might be silly but is your ac on when you saw this?
Old Jun 2, 2010 | 08:26 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Sounds like a sensor, could be the TPS or IACV
Old Jun 2, 2010 | 09:12 AM
john6699's Avatar
I was thinking sensor.
Yes the AC was on I will try with AC off shortly
Old Jun 2, 2010 | 10:55 AM
john6699's Avatar
It doesn seem it runs a little ruff and runs the same with AC OFF
Old Jun 2, 2010 | 12:54 PM
john6699's Avatar
where is the IACV and TPS at can I test or clean them some how
Old Jun 2, 2010 | 02:03 PM
john6699's Avatar
A friend I mine said to seafoam it, do u think that will fix it.
Old Jun 2, 2010 | 07:11 PM
john6699's Avatar
Seafoam didn't work here is a youtube on what the car is doing.
hxxp://www.youtube.com/watch?v=OwLgffl2mjU
replace hxxp with http.
Please let me know what u think it is and if there is a guide on how to fix it thanks
Old Jun 2, 2010 | 07:42 PM
asianspec's Avatar
did you check what code you have with that check engine light.
Old Jun 2, 2010 | 07:52 PM
john6699's Avatar
no because It has been on for years it would go on and off for no reason. I took it the dealer and they kept saying it was the gas cap not being tighten.
So I have a feeling it would be a false but tomorrow I will take to see if I can get a code.
I am leaning towards IACV but can't find a good sticky on how to clean it out
Old Jun 2, 2010 | 09:19 PM
P0401's Avatar
I am guessing you didn't take anything apart while it sat did you? the reason I ask is anytime I see something like this the first thing that comes to mind is vacuum leak somewhere. I have not had very many computer cars with all the sensors so I could be way off on this but still figured I would ask if anything that has a seal had been removed for anything at all or loosened while it sat for so long
Old Jun 2, 2010 | 09:47 PM
john6699's Avatar
no didn't take anything off
Old Jun 3, 2010 | 01:09 PM
john6699's Avatar
got the TB off but don't know what type of screw the IACV is not torx
any idea
It is 5 points
DerrickW
Nov 15, 2015 05:52 PM
Houston
Oct 8, 2015 01:27 AM
wubly
4G TL Problems & Fixes
Oct 6, 2015 02:45 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
ROSSARONIE
Sep 22, 2015 11:46 AM
