Question new engine
Old Jun 15, 2007 | 12:36 AM
Dmaxdouglass's Avatar
Question Question new engine
Hey I have a 98 cl with a 3.0 and just had to put a motor in it. I got a really great deal on a motor out of a 97 and now it seems like the car does not have th power and when the rpms are held above 3500 or so the check engine light comes on and it will not go above 2 or 3000 I can'nt rebember been babying it. Do you guys have any thing that I can do.?.? I miss how the car use to run and would like to get it back to the old.
Thanks,
Robert
Old Jun 15, 2007 | 01:38 AM
saiko_cl_duck's Avatar
Have a code scanner?
Pull the code and see what it says.
Sounds like either the the tranny is going, or something just isn't hooked up right.
Old Jun 15, 2007 | 01:09 PM
Okay I will get the code.
Old Jun 15, 2007 | 08:31 PM
AznX TL's Avatar
where is....
its probably distributor related, and its probably in limp mode right now.
Old Jun 16, 2007 | 05:14 AM
How do I get it out of the limp mode???
Old Jun 16, 2007 | 08:15 AM
Mach30SiR's Avatar
Bagel Bomber
You'll need to pull the code first. Hit a local autozone and they will pull it for free. After you fix the problem, clear the code, your car will be out of limp mode. I wouldn't drive too much because your gas mileage is probably crap right now.
Old Jun 23, 2007 | 05:22 PM
Well I pulled the code and it is a P1259. The reader said Fuel Air Managment.?.? The car is a 98 and I put a motor out of a 97 also do I need to run premium fuel?? Thanks for the help.
Robert
Old Jun 23, 2007 | 07:34 PM
AznX TL's Avatar
where is....
means either the fuel/air mixture is too lean or too rich.
Yikes
May 3, 2021 04:29 PM
drone619
Jan 26, 2016 07:09 PM
wusty23jd
Sep 24, 2015 11:41 AM
Billu99tl
Sep 13, 2015 11:30 AM
datadr
Sep 12, 2015 09:12 PM
