on to problem two help p1259 engine light
so as many of you may or may not know my engine got hydrolocked. so i had the engine switched out and bamn great for me i get a check engine code, the engine runs good up to 4k and than it wont let me go past that, so i go to check the light and it gives me p1259 mtf controlled fuel and air metering. now wtf does that mean???? help me out please i;m really to explode and i cant spend any more money on this car.
Some one please help cuz mine is doing the SAME exact thing. But its not all the time. It gets up to 4 grand and then starts jerking. It almost feels like you are red lining. Mine started yesterday. It did it before and i reset the computer and it didnt do it for awhile then it started again. BTW i got the same engine code.....
check on how much oil you have in. if oil pressure is too low it will not go into vtec. or it could be a bad vtec solenoid, or oil pressure sensor. theres gobbs of sensors that can thro codes for air fuel mixture. make sure there are no vaccume leaks, and make sure everything is plugged in.. look around the oil filter and there should be 3 to 4 connectors there, make sure they are all installed all the way and not loose. an check the vtec solenoid to make sure its actually plugged in. check all that stuff and post back.. if its running fine up to that point its got to be something simple.
last time this happened i went to honda and did an oil change and it stopped the problem, what really bothers me its that this is a completely different engine. two engines doing the same thing seems like a computer problem.
Originally Posted by ShavedH22CL
Whats up man i met you at best buy last night redcl
Im having multiple problems with a 99 CL. First, the transmission is going out. My new problem is that when I took it to a transmission shop to put it on the computer, there are NO codes that show up, just Zeros. I took this car to an Acura dealer 3 days ago. I do not know if they put it on the computer or not , they just told me it needed a new transmission. Now I wonder if they could have done something to it to keep anyone from seeing what is wrong with the car?
No they didn't do anything wrong to the car, a lot of times the codes just don't get triggered until the tranny fails. Does it give you problems on a cold start first thing after you started it up? That's the only way I could get the tranny shop to even find my problem, had to leave it there a few days and fight with them about it b4 they even recognized a problem
RE 99CL computer failure
It does this cold or hot. Im hoping that its just the solenoids. The transmission shop felt like they could find the problem if they had time to wipe out the computer and reformat it, by reloading the program. So you dont think that the computer is out... its just a glitch that can be fixed?
HeloDown
Sep 8, 2015 06:51 PM
