problem
Old Apr 12, 2007 | 11:06 PM
jgrnCL's Avatar
My CL is For Sale..
problem
so i took my car to a shop to do an oil change since i was too lazy to do it and after i got the car back i noticed when i was driving to work that the MPH's werent working or my mile marker. everything else on the gauge cluster works except those two things. anyone have an idea on what it is???
Old Apr 12, 2007 | 11:10 PM
mcajka's Avatar
Death to Fresh
HAHAHAHA....OMG that is my same problem now....after i got my oil changed a long time ago it happened....my miles and mph will work occasionally...idk if anyone knows let us know ASAP
Old Apr 12, 2007 | 11:59 PM
jgrnCL's Avatar
My CL is For Sale..
im guessing its the Vehicle speed sensor but i wanna make sure
Old Apr 13, 2007 | 08:51 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Vss
Old Apr 13, 2007 | 09:09 AM
Jays99CL's Avatar
ACURA FTW!!!
wow thats gotta suck!!
Old Apr 13, 2007 | 09:41 AM
jgrnCL's Avatar
My CL is For Sale..
how much am i looking at? ($$$$)
Old Apr 13, 2007 | 09:50 AM
jgrnCL's Avatar
My CL is For Sale..
where is the vss located???
Old Apr 13, 2007 | 01:18 PM
Nakamichi's Avatar
~[ô¿ô]~
Auto #12
Manual #8
Old Apr 13, 2007 | 03:37 PM
TexasHonda's Avatar
VSS fault sets Code 17 on CEL. If you don't have a code, your IP wiring, or speedo/odo/trip circuit board likely has failed.
good luck
Old Apr 13, 2007 | 04:30 PM
jgrnCL's Avatar
My CL is For Sale..
thanks yeah i got code 17
Old Apr 14, 2007 | 11:43 AM
TexasHonda's Avatar
Check ebay for replacement VSS. Plenty of parts available. Easy DIY.
good luck
Old Apr 14, 2007 | 03:34 PM
jgrnCL's Avatar
My CL is For Sale..
hey changed the vss. everything works but now the RPM's are going crazy. i checked the code and now i got code 65. would that be the problem??
Old Apr 14, 2007 | 04:03 PM
jgrnCL's Avatar
My CL is For Sale..
btw i got the vss off a 4 gen accord not the 94-95's. dont know if its the same
Old Apr 14, 2007 | 07:31 PM
TexasHonda's Avatar
RPM jumping is usually associated w/ faulty ignition parts; ignitor, coil, wires, or plugs or all of them. Start w plugs if you haven't done that in a while.
Code 65 indicates a fault (open or short) in the secondary O2 sensor heater circuit. This usually means the heater element is open (burn out), but can mean wiring or connector fault. I would first reset the ECU and see if code comes back immediately. If yes, a new O2 sensor is probably fix, but check wiring and connector for damage.
good luck
Old Apr 14, 2007 | 07:34 PM
(Mid-Atlantic)
As long as you're a 2.2 it should be
Old Apr 14, 2007 | 09:30 PM
jgrnCL's Avatar
My CL is For Sale..
k thanks. imma see if i fix the problem tommorow
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
