problem
problem
so i took my car to a shop to do an oil change since i was too lazy to do it and after i got the car back i noticed when i was driving to work that the MPH's werent working or my mile marker. everything else on the gauge cluster works except those two things. anyone have an idea on what it is???
Originally Posted by jgrnCL
hey changed the vss. everything works but now the RPM's are going crazy. i checked the code and now i got code 65. would that be the problem??
Code 65 indicates a fault (open or short) in the secondary O2 sensor heater circuit. This usually means the heater element is open (burn out), but can mean wiring or connector fault. I would first reset the ECU and see if code comes back immediately. If yes, a new O2 sensor is probably fix, but check wiring and connector for damage.
good luck
btw i got the vss off a 4 gen accord not the 94-95's. dont know if its the same
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
