Engine light diagnostic on a ’98 2.3 CL?
Old May 31, 2007 | 07:44 AM
nickbeee's Avatar
I saw the post here (NOOB Post) but it’s titled codes for 3.0. Is the procedure the same for the 2.3 (manual)? Same pins shorted and same codes?
Thanks!
Old May 31, 2007 | 10:50 AM
saiko_cl_duck's Avatar
same, as far as I know.
If you have an Autozone or Advance Auto near you, they'll run the scan for free.
Old May 31, 2007 | 11:36 AM
nickbeee's Avatar
Ya I’ve read that, but I’d rather save the trip. Does anyone know if I should be using the connector under the steering wheel (I think there is one there) or the one behind the ashtray? I guess I could go to an autozone on the way home, but would rather just walk down to my car with a paperclip… BTW, I have a ’98 2.3 CL Manual..
Thanks Guys!
Old May 31, 2007 | 12:00 PM
umm, just stop by Autozone. It will take less than two minutes, and you won't mis-interpret the code.
Old May 31, 2007 | 11:07 PM
Nakamichi's Avatar
~[τΏτ]~
You need to use the service connector under the passenger side. It's a 2-pin (blue on 3.0) connector that plugs into a empty socket.
Jump that connection using a paper clip, put ignition to ON position (but don't start engine) and reference the code in the NOOB guide . All that's different is there is not misfire on cylinder 5 and 6 (obviously).
If all else fails take saiko_cl_duck's advise and goto Autozone. Good luck.
Old May 31, 2007 | 11:31 PM
AznX TL's Avatar
where is....
i would rather go to autozone and get the code, most of the time they can even help you in telling you what part needs to be replaced for the code.
Old Jun 4, 2007 | 10:19 AM
nickbeee's Avatar
So I put going to AutoZone on my to-do list for Sunday. I got in my car, made one stop at a hardware store,, got back in my car, started it up, and the CEL went off (and has stayed off). I guess it goes off by its-self if the problem does not persist?
Thanks!
Old Jun 4, 2007 | 10:22 AM
nickbeee's Avatar
Engine boggs sometimes on idle..
Recently I’ve noticed that my engine’s idle dips sometimes. I think it happens more with the AC on. It will go down from it’s normal 1K to 250ish,,, then recover back to 1K. I have a ’98 2.3 CL with 205K miles. Could it be a sign of something? Like an alternator that is starting to go?
Thanks!
Old Jun 8, 2007 | 10:20 AM
nickbeee's Avatar
So the light came back on yesterday,,, looks like I should get to autozone before it goes off...
Old Jun 8, 2007 | 08:07 PM
AznX TL's Avatar
where is....
even if it does go off its still stored in your ecu until its reset.
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
