Door latch/window regulators
Old Mar 6, 2006 | 06:34 PM
trenth1028's Avatar
5th Gear
Question Door latch/window regulators
Need a door latch for a 97' 3.0CL, also need both window regulators. Would like to know if any Honda parts are interchangeable.
Old Mar 6, 2006 | 08:27 PM
jumpmanbsktbll's Avatar
2.4 L iVtec
ebay
Old Mar 7, 2006 | 03:21 AM
saiko_cl_duck's Avatar
94-97 accord window regulators, either ebay or try 1aauto.com
Old Mar 15, 2006 | 04:25 PM
Grn3.0CL's Avatar
7th Gear
does anyone have a door layout?
Old Mar 16, 2006 | 07:22 AM
Sfinlen's Avatar
Roll Tide!
See if this helps.....
http://www.acuraautomotiveparts.org/...prddisplay.jsp
Just put your car info in and then where it says system/component go to door panel
Old Mar 17, 2006 | 12:05 AM
check this out https://acurazine.com/forums/showthr...ghlight=window
Old Mar 26, 2006 | 12:58 PM
krazy99cl's Avatar
O.G.
best bet is ebay for the regulators
Old Apr 14, 2006 | 10:32 PM
ShibbyDevil's Avatar
Doom dee doooooom
err which door? I have some parts sittin around for a pass. door.
Ryan
Old Jul 24, 2006 | 12:15 PM
TKT-GETR's Avatar
5th Gear
Bumping this thread because I have a question. I was told (by Acura parts dept)that the 2.2 and 3.0 CLs use different window regulators? Can anyone confirm that a 2.2 regulator assembly will NOT work on a 3.0?
I have searched the web/ebay and everyplace is selling 2.2 regulators and not 3.0! The 2.2 version also works on the Accords as mentioned above.
According to Acura:
72210-SV2-013 is for 2.2 CL
72210-SY8-A03 is for 3.0 CL
FWIW, I need a 3.0 passenger side unit. The cable latch broke and now the 'up' cable has become wound up inside the motor.
Thanks,
Old Jul 26, 2006 | 04:50 AM
According to Acura:
Thanks,
Those guys are morons. A 1st gen regulator is the same, no matter what. how would the engine size cause the regulator to be different. They're just trying to hose you around
Old Jul 26, 2006 | 08:27 AM
TKT-GETR's Avatar
5th Gear
Yeah, I figured that. It didnt make any sense to me either, but I called two different dealers and they both said the same thing.
In any case, I found a dealer that would sell me a new OEM unit for $120 shipped, so I went that route. I know there were some aftermarket units for like $80, but I'm willing to pay more for OEM and no hassles.
Old Jul 29, 2006 | 10:29 AM
Slooo97CL's Avatar
good idea the aftermarkets suck compared to the OEM's
Old Jul 29, 2006 | 09:59 PM
Doom dee doooooom
actually i think they are different. the 3.0 has a one touch feature which i believe is controlled in the regulator. The pass side should work for either one. I only say this because if you buy an aftermarket one you loose the one touch.
Old Jul 29, 2006 | 10:06 PM
AznX TL's Avatar
where is....
mine has 1 touch, and its the 2.2cl base w/o leather
Old Jul 31, 2006 | 02:46 AM
no difference, one touch came on 2.x's
soupi
14
Nov 15, 2015 11:15 AM
BIGxRED
Oct 19, 2015 10:47 PM
xsilverhawkx
Sep 28, 2015 06:51 PM
chiu0nthls
3G MDX (2014-2020)
Sep 28, 2015 03:46 AM
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
