Door latch/window regulators
5th Gear
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
Need a door latch for a 97' 3.0CL, also need both window regulators. Would like to know if any Honda parts are interchangeable.
Roll Tide!
See if this helps.....
http://www.acuraautomotiveparts.org/...prddisplay.jsp
Just put your car info in and then where it says system/component go to door panel
Bumping this thread because I have a question. I was told (by Acura parts dept)that the 2.2 and 3.0 CLs use different window regulators? Can anyone confirm that a 2.2 regulator assembly will NOT work on a 3.0?
I have searched the web/ebay and everyplace is selling 2.2 regulators and not 3.0! The 2.2 version also works on the Accords as mentioned above.
According to Acura:
72210-SV2-013 is for 2.2 CL
72210-SY8-A03 is for 3.0 CL
FWIW, I need a 3.0 passenger side unit. The cable latch broke and now the 'up' cable has become wound up inside the motor.
Thanks,
According to Acura:
![Annoyed](https://acurazine.com/forums/images/smilies/annoyed.gif)
Thanks,
According to Acura:
Thanks,
According to Acura:
Thanks,
![Owned](https://acurazine.com/forums/images/smilies/owned.gif)
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
In any case, I found a dealer that would sell me a new OEM unit for $120 shipped, so I went that route. I know there were some aftermarket units for like $80, but I'm willing to pay more for OEM and no hassles.
Yeah, I figured that. It didnt make any sense to me either, but I called two different dealers and they both said the same thing.
Doom dee doooooom
actually i think they are different. the 3.0 has a one touch feature which i believe is controlled in the regulator. The pass side should work for either one. I only say this because if you buy an aftermarket one you loose the one touch.
soupi
14
11-15-2015 11:15 AM
xsilverhawkx
09-28-2015 06:51 PM
22, 72210sy8a03, acura, cl, door, forum, honda, interchangable, og, panel, part, regulator, regulators, tl, window
