Brake issue
Old Feb 19, 2008 | 04:34 PM
themadmarmoset's Avatar
JAPCARLUVR
Exclamation Brake issue
Recently, my ABS light came on while driving. After turning off and restarting, the light cleared itself but comes back on occasionally, only going off after shutting the car off. I think it may be an ABS sensor, but then I noticed coming to a complete stop, at the end, it feels like the brakes clench up a bit. Today, the brake indicator on the dash came on, is this a heads up that brakes need to be replaced?
Old Feb 19, 2008 | 06:52 PM
TexasHonda's Avatar
Get ABS codes by shorting the Service Check Connector (blue 2-wire connector under glove box) and counting the ABS light flashes (all short flashes). It's a two part code ffff-p-f = code 41. The pause is about same length as flash. There could be multiple codes w/ a long pause separating each code.
Post back your codes and perhaps I or someone else can help.
good luck
Old Feb 20, 2008 | 01:05 AM
JAPCARLUVR
Lightbulb Shorting
Exactly how do I short it out?
Old Feb 20, 2008 | 08:31 AM
young03's Avatar
its JDM yo!!!!!!!!
check brake fluid level also to ensure there is enough fluid in there
Old Feb 20, 2008 | 06:03 PM
TexasHonda's Avatar
A short jumper is simply a piece of wire connecting both pins of the connector. Install, turn keyswitch to ON, and read ABS flashes.
good luck
Old Feb 21, 2008 | 08:21 AM
JAPCARLUVR
Thanks for all of your support in the posts, I really appreciate it.
mada51589
Jan 9, 2025 04:40 PM
HOWELLiNC
Sep 10, 2015 01:39 PM
jliu6789
Sep 8, 2015 08:02 PM
mav888
1G RDX (2007-2012)
Sep 8, 2015 11:49 AM
nishant11
Sep 2, 2015 10:34 AM
