Window regulator replacement
Old Jul 27, 2005 | 01:59 AM
starboy2nv's Avatar
First EVER K24 Turbo CL
credit goes to BOBUTLER for the original write up and pics
http://home.comcast.net/~bobobutler/...ra_Window.html
Old Oct 7, 2006 | 05:57 PM
Yelhsacm's Avatar
3rd Gear
Thanks!!
Old May 23, 2008 | 12:30 AM
GhettoNinja06's Avatar
Skuuuurrrrrt!
Thank you! I have to try this soon. Window reg is on it's way.
Old Dec 16, 2009 | 05:21 PM
CLphx's Avatar
The link is not working for me. Does anyone have an alternate way of accessing this DIY????
Old Dec 16, 2009 | 08:47 PM
shnee's Avatar
Land of Pleasant Living
I thought there was another set of instructions somewhere on here, though this bobutler DIY was what I used. But maybe there isn't, I'm not sure. But I would definitely search around some more.
I DO know for a fact you can find free instructions online for an Accord. Google around. I know they exist because I looked them up when I did my girlfriend's, just to make sure there weren't any real differences between the CL and Accord regulators. I don't have a link though, sorry.
Old Dec 16, 2009 | 09:04 PM
saiko_cl_duck's Avatar
It's not hard.
Take out the screws on the door latch (interior), the door handle, and the plug near the hinge (looks like a cover piece). Remove the liner carefully, and the rest is pretty easy to figure out. Just slide the window down enough to access the two bolts holding in the glass to the slide, and undo the four bolts that hold the assembly in place. It's real easy once you get in there. I'll see if I can find the old one.
Old Feb 6, 2010 | 12:11 PM
Random_Baller's Avatar
That link's dead. Anyone have a mirror or link to another DIY?
Old Feb 7, 2010 | 11:18 AM
shnee's Avatar
Saiko gives you the basic idea anyway. Just unscrew a couple of things and pop the interior door cover off from the tabs, unplug the wires that are holding the cover to the door, and then it's just a few bolts behind the liner. Look for the Accord directions though, they show you everything to do.
Old Feb 7, 2010 | 05:50 PM
mitch14's Avatar
CL in lawnmower status
posted it back up in it's own thread, so it's easier to see
Old Jun 3, 2012 | 01:15 PM
bobcov's Avatar
For those of you coming late to the part, like me (June 2012), here is an excellent YouTube video going through the entire procedure for what looks to be a 99 3.0CL (with a broken driver's door handle, btw. What is not clear to me so far is what brand of regulator is best. I'm going to try Dorman unless somebody here tells me not to. My passenger side regulator is gone and I figure I won't be using that window very much so a cheap one may do instead of a more expensive one.
Old Jun 5, 2012 | 09:02 PM
bRunCL's Avatar
thats a very thorough video. looks to be a little bit newer tl tho...I replaced mine with what I believe was a "dorman" brand but im not 100% sure. worked fine, biggest issue i ran into was the oem part had bolts that went into the motor to hold it into the door frame. the replacement had "studs" that required nuts to be threaded on them to secure it to the door frame. a run to the hardware store and i was good to go.
Old Jun 6, 2012 | 08:58 AM
bobcov's Avatar
Good to know about the Dorman. That's crazy because their promotional videos go on and on about how exacting their replacements are. Meanwhile, back at the ranch, I found that I can buy an entire door for my 99 for $75 from a local junk yard. I will just get the regulator out of it for $25. It will give me an opportunity to see exactly how everything comes apart without worrying about making beginner's mistakes on my own car. And for $25, I'm willing to roll the dice on longevity.
TLDude876
Dec 28, 2016 03:18 PM
mazen222
Oct 27, 2015 12:01 AM
NBP_BALLER
Sep 23, 2015 08:18 PM
ahsm
Sep 9, 2015 08:35 AM
asahrts
Sep 4, 2015 05:55 PM
