wierd problem
Old Aug 12, 2004 | 09:37 PM
dumbaznboy's Avatar
wierd problem
i started my CL today (after a few weeks of not using it) and the engine began to rev like I was tapping the gas...
it would rev up and come back down and rev up again and this would keep repeating.
the check engine light is on as well.
any thoughts?
Old Aug 12, 2004 | 09:38 PM
liloj's Avatar
i like orange juice
idle control valve thingy
Old Aug 12, 2004 | 09:39 PM
oneilc's Avatar
Kenpachi Teichou
computer possibly relearning idle
Old Aug 12, 2004 | 09:40 PM
dumbaznboy's Avatar
so do i let it sit?
or should i restart the ECU (IE...unplug the battery)
Old Aug 12, 2004 | 09:54 PM
liloj's Avatar
i like orange juice
get your light checked first to make sure thats it before you reset it...then..if it is..reset....if it comes back..then the ICV is messed up
Old Aug 12, 2004 | 09:56 PM
dumbaznboy's Avatar
how do i get my chceck engine light checked?
all i got from the manual was to make sure the gas cap was turned at least 3 clicks.
Old Aug 12, 2004 | 10:23 PM
dumbaznboy's Avatar
well heres some more info, as it was my dad who first started up the car today.
he said that when he first started the car, it did what i described but the gas pedal wouldnt respond..he'd press, and he'd get no acceleration.
so i just unhooked the battery for like 5 mins and after doing so, and letting the car do its wierd idle for like 2 mins, the check engine light went away, and the gas pedal now responds. but the car still idles weird (in park) and when we're not braking, the car gains speed (without the accelerator)...
im thinking to unhook the battery once again, this time longer, and letting the car idle for like 10 mins. hopefully this will solve things.
any input would be appreciated.
Old Aug 13, 2004 | 02:06 AM
krazy99cl's Avatar
O.G.
well if your check light went on...then bring it to a parts store or a friend that has one of those connectors that reads you out the problem...sorry forgot whats its called.....but it should link up to the back of the ash tray.....pull the ash tray out and you'll see like a computer input.....! some suggestions.....
Old Aug 13, 2004 | 02:31 AM
dumbaznboy's Avatar
well the check engine light turned off after i removed and replaced the gas tank cap and "reset" the ECU.
Old Aug 13, 2004 | 02:54 AM
babyloc86's Avatar
i think ur check engine light will come back on. cuz when i had it on, it would go away n the light will come back again later.
Old Aug 13, 2004 | 05:08 AM
97Black2.2CL's Avatar
got audio?
Maybe your idle air valve? I had that problem in my Integra. Do the revs go up and down or just stay in one position?
Old Aug 13, 2004 | 11:52 AM
dumbaznboy's Avatar
when i first start the car...it would go right up to 2000rpms...then it would drop to about 1500 and rev up to 2000 and drop back to 1500 and back up to 2000...and it would repeat.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
