Wet Carpet from AC!?!
Wassup guys
Im here again with another dilemma. My carpet get soaked after a long time of driving and i think its cause of the AC. The Front driver and passenger side.
What is a man to do in this case.
search for wet leak or tube leak or something along those lines or ac* leak people have had this problem before, it's a backup in a pipe under your dash
Originally Posted by WineRed2.2CL
Wassup guys
there's a rubber hose behind the glove compartment, it might have gotten plugged. pull it out, make sure you have some towels beneath it to catch the water, and use some compressed air or a piece of long cable, etc, to remove the plug.
that what i did when it happened to me last time. it hasn't happened again since then
OK so check inside the car under the steering wheel and under the glove box?
Im going to try it out thanks fellas.....carpet was smelling like some FUNK
Mine recently started pouring water from too, turns out it was that clogged hose, here's another thread on this, if you're still having problems...
https://acurazine.com/forums/showthr...highlight=leak
P.S. First Post!
P.S. First Post!
acura_dipset_tl
Jan 1, 2016 03:02 PM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
