weird startup problem
Old Mar 24, 2005 | 02:20 AM
rEmixnZZa's Avatar
just recently (a day or 2 ago) my car has been acting weird during start. When i first turn the key, the power comes on and everything but the car clicks once and nothing happens. then i just turn the key again and it starts. usually takes 2 or 3 turns before it starts. not sure what the problem is, but once the car starts there's no problem, and the lights/radio all work so i don't think its the battery. Anyone have this problem? its not cold or raining or anything like that
thanks
-btw im probably going to the socal meet on saturday @ fuddruckers
anyone else going?
Old Mar 24, 2005 | 08:42 AM
aRIff's Avatar
Ottoman Empire
it looks to me your starter is dying...
Old Mar 24, 2005 | 09:39 AM
pebe's Avatar
get that changed asap.
Old Mar 24, 2005 | 12:17 PM
froggystyle14's Avatar
"FROGGYSTYLE"
your battery connections might be loose....if you can pull the cables of the battery with no problem then you might run into a problem of corrosion (spelling) build up and would cause starting problems
Old Mar 24, 2005 | 12:58 PM
rEmixnZZa's Avatar
how much is it to repalce a starter? and is it a DIY?
actually froggy that might be the case...my battery cables were always a little loose but i couldn't really tighten it all the way, and thought it wouldn't be a problem
do i need to clean up the corrosion? or just tighten the cables
thanks for the help guys
Old Mar 27, 2005 | 05:36 PM
Nati_Bra's Avatar
I've got the same problem, started about a week ago or so... 97 3.0 hmm 81k
Anyone know if a 98 accord 2door starter can swap???? please help us!!!
Old Mar 27, 2005 | 06:03 PM
endlessdragon's Avatar
~ The Endless One ~
check your battery fluid and terminals
Old Mar 28, 2005 | 08:23 AM
Nati_Bra's Avatar
Don't know bout Ermixnzza but my battery is Not even one year old, I'll try the corrosion thing,
but my gut tells me it's the starter... Still wondering about swaping for the accord starter???
Old Mar 28, 2005 | 09:36 PM
Nati_Bra's Avatar
would have swore it was the starter .... Got the low Down!!! the odessy, tl, cl and accord v6 starters match up, to rebuild is about $100.. Hit up Auto Zone and you can test it for FREE , found out my starter is fine ordered a replacement ground wire pack from ACURA $19.99 hope you get yours tested first, looked like on the 3.0 the starter is on the driver side mid way down ... yours might be DIfferent it's sometimes on the other side ..........
Old Mar 29, 2005 | 03:27 PM
rEmixnZZa's Avatar
thanks for the info
the problem went away...all i did was play around w/ the battery cables hand its been starting fine
weird ill try to get it checked sometime anyways
Old Mar 29, 2005 | 04:15 PM
LCARUCA 97's Avatar
Trailblazer = SUCK
check to see if you are covered under the ingition recall. sounds like the symptoms of either the the ignition switch, the main relay, or the starter/solenoid.
Old Mar 29, 2005 | 08:47 PM
rEmixnZZa's Avatar
already did the ignition recall a long time ago
Old Apr 5, 2005 | 11:49 AM
Nati_Bra's Avatar
Also had the recall a while ago, replaced the ground wire, the problem got BETTER but is still there, I don't think it's the starter, I think it's the RELAY>> the RELAY is cheap i think???
LCACURA 97 you don't happen to know about were this relay is do you??? I'm guessing firewall drivers side somewhere, haven't even looked yet.. Anyways I will probly DIY and will take pics for other people with the same problem!! THNKS
Old Apr 5, 2005 | 12:00 PM
LCARUCA 97's Avatar
Trailblazer = SUCK
its under the hood in the fuse box. there is another relay that has to do with the ignition under the steering wheel too.
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
Skirmich
Oct 1, 2015 12:59 PM
merc009
Sep 29, 2015 03:06 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
