vibration problem
Old Apr 27, 2004 | 12:16 AM
andy_bigstar's Avatar
vibration problem
Anyone have a vibration problem when idlling and stop at the light while in gear????? The car runs fine and smooth but had vibrations when stop or idlling only when the engine is warm.
The idlling speed is fine and just did all the major tune up stuff, change the fuel filter, air filter and front engine mount.
I think is the timing belt got stretch causing the timing to go out while in low rpm like idlling. But I could be wrong.
Any ideas will be most welcome. Please help
Old Apr 27, 2004 | 05:45 AM
Sir's Avatar
Sir
CL = Can't Lose.
I have no clue and my car does the exact same thing. : /
Old Apr 27, 2004 | 10:50 AM
fusionnv's Avatar
Gimmie my points Biatch!
Re: vibration problem
Does it go away. My CL and my prelude did the same thing. I think it has something cycling inside the car when it is not moving. I also notice that when the AC is off it doesn't really do it much or at least that I can notice it where it bothers me.
Old Apr 27, 2004 | 12:30 PM
jerseyclguy's Avatar
Mine does the same, I noticed when stopped but in gear my dash shakes. I was thinking maybe a tune up?
Old Apr 27, 2004 | 11:53 PM
I think it can only be tune up, engine mounts, vacuum system, injector needs cleaning, timing belt (old and need to be change), one of this is got to be the cause of this..........right?
Old Apr 28, 2004 | 07:15 AM
joeshmoe's Avatar
My Home Planet
Could need a valve adjustment.
Old Apr 28, 2004 | 08:14 AM
dogfight's Avatar
Most car's have a "modulator" that controls the interaction between the engine and (auto) transmission... could be faulty and sending wrong signals.
Old Apr 28, 2004 | 08:40 AM
christopher g's Avatar
try changing the other two engine mounts this is a common problem
my 2.3 cl is doing it as well I need to get them done.
I read a post on Honda tech and a guy with a Cl complained about the same problem he changed his timing belt, plugs, wires, cap, rotor, pvc, egr, front mount, injectors, did a fuel flush and it still was doing it. He changed his front or left mount and the problem was fixed.
Old Apr 28, 2004 | 02:42 PM
VXCL's Avatar
AWD Torque Monster
my car does the same thing. i just changes oil & tranny fluids, new plugs and indexed them, wires, cap, rotor, and valve adj and still does it. it always did it though. just alittle more rough when i got an intake.
Old Apr 28, 2004 | 02:55 PM
If you think of this in a logical way the engine mounts damper vibration from the engine and if they are worn vibration will be prevealent at idle and at worse case scenerio when you stomp on the gas and the mounts are under an extreme load
Old Apr 28, 2004 | 02:57 PM
you can also get a rough idle if you install cams, intake, have a vacuum leak, or your timing is out of whack.
Old Apr 28, 2004 | 05:39 PM
sabugod's Avatar
3rd Gear
I had a similar problem until I changed two gaskets in the manifold, that were also leaking just a little bit of the exhaust. Problem solved, smooth running since then.
Old Apr 30, 2004 | 12:18 AM
I had the valves adjusted and that did'nt help so I M going to change the timing belt next week as it needed to be change anyways. I hope that will help, I'll let you guys know how it turns out and thanks for replying. cya
Old Apr 30, 2004 | 12:25 AM
Hey christopher g......can u let me know if it sovle the problem after u change your engine mount?
4drviper
Apr 23, 2025 07:13 PM
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
joflewbyu2
Oct 8, 2015 11:16 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
