is it the starter?
Old Oct 1, 2006 | 05:08 PM
jumpmanbsktbll's Avatar
2.4 L iVtec
is it the starter?
car wont start
everytime i turn the key, it just clicks
light come on/radar comes on/clock comes on
prob the starter right?
Old Oct 1, 2006 | 05:29 PM
5-speed's Avatar
4x4- fat chicks cant jump
try to jump it. the acc. will come on sometimes even if the battery is too low to start it.
Old Oct 1, 2006 | 06:51 PM
TexasHonda's Avatar
Make sure your battery connections are good and that battery is charged.
If battery and connections are good, the cause is most likely worn starter solenoid contacts. They wear at each start due to electrical arcing. Fix is to either replace starter or replace the solenoid contacts inside the solenoid (starter removal required).
If you want to repair the solenoid, try Sherco Auto Supply for contacts. They have a website and online catalog. You will need the old contacts to be sure you order correct contacts.
good luck
Old Oct 1, 2006 | 07:22 PM
zguy95135's Avatar
It if clicks, its most likely the starter. Our Cadillac starter went out four times, so I'm pretty accustomed to the sound.
Old Oct 1, 2006 | 08:34 PM
2.4 L iVtec
ok so: I took the battery cover off and found that the positive plug was corroded, so I cleaned it off and put some de corossive crap on it. Then my dad tried jumping it and it still didnt start. So i went inside and went back out and tried it again a few times and still nothing. Came back out, tried it once but nothing, then I just left the key in for like 30 seconds cause I was paying with my hu, and I tried it again and it started. I have no idea why? I took the key out and kept starting it and it worked fine...
Old Oct 1, 2006 | 08:38 PM
starboy2nv's Avatar
First EVER K24 Turbo CL
its your starter....
Old Oct 1, 2006 | 09:09 PM
Orlando3.0's Avatar
Fast Foward>Rewind>Play
wasnt this part of the recall thing too? my car does it, doesnt bother me much.
Old Oct 1, 2006 | 09:18 PM
97Acura3.0CL's Avatar
ENGAGE MY VTEC BABY!!!!!!
if it is your starter it will click over and over
look in the yellow pages, I was able to find a place to rebuild mine for cheaper than buying a new on and they painted it black too at no charge
Old Oct 1, 2006 | 10:46 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
It's def the starter, just had mine replaced with a brand new one for $200. If it clicks it's def the starter, you can get it to start, just try crankin it like 4-5 times, it'll start. My alternator guy showed me that, you have a bad spot in the starter, crank it 4-5 times it'll start. Def the starter though
Old Oct 1, 2006 | 11:25 PM
2.4 L iVtec
dammm
will it be able to always start after like 4-5 clicks? Cause i got it to start and ive started the car up like twice tonight with like 3 hour intervals
or should i just get it replaced asap?
Old Oct 2, 2006 | 12:03 AM
SwervinCL's Avatar
Nom Nom Nom Nom
Starter
Old Oct 2, 2006 | 01:49 AM
Sleep_DEPRIVED_Sleeper's Avatar
Turtle Charged, Biotcch!!
It's definitely the starter unit, replace it, it will suck @$$ when you're stuck far away from home/help...it happened to me once, I was going south to san diego and after stopping to expunge...it didn't start and i had to pay $400+ for towing back to OC and replacing the unit...
moral: Fix it and fix it now...
Old Oct 2, 2006 | 03:11 AM
zguy95135's Avatar
It shouldnt be too hard to fix, afterall its sitting right there.
Old Oct 2, 2006 | 06:05 AM
TexasHonda's Avatar
Replacement solenoid contacts are < $15 for a lifetime supply (10 each). Repair requires use of a soldering iron (100 w or better) and only modest mechanical skills.
good luck
Old Oct 2, 2006 | 08:39 AM
(Mid-Atlantic)
Originally Posted by jumpmanbsktbll
dammm
For a while, but it'll just get worse. Like I said b4, that means that you have a bad spot in the starter, cuz you are passed it now, and you're starting again. Same thing happened to me, but I got mine replaced, cuz I have to be able to start my car. Just get it fixed, maybe your blue paint killed your starter, i painted my eb around the same time you did, and my starter kicked Just playin man
Mike Pilipenko
Mar 26, 2024 09:21 PM
Jul 16, 2017 07:33 AM
agupta3224
Sep 22, 2015 08:08 PM
lovic87
Sep 15, 2015 06:07 PM
