rewire front turn signals
Old Mar 5, 2009 | 06:52 PM
shogo2.3cl's Avatar
anyone know how to rewire the front turn signal lamps to stay on when the parking lights are on , and flash when activated
Old Mar 5, 2009 | 07:12 PM
shogo2.3cl's Avatar
also how did Klepto have the amber/yellow lights in his highbeam part of his headlight?
did he wire a 168/194 bulb over there
Old Mar 5, 2009 | 10:55 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Search Search and Search
Klepto put his corners into his highbeams yes, others have done it with led's but they don't last.
As for the corners and turn signals, you need to get an integra relay and wire it in, there's a write up on here
Old Mar 6, 2009 | 02:50 AM
hOnU's Avatar
Da HoNu
i've seen in person what/how klepto rewired his corners over to the high beams..had wires going across the engine bay, kinda krazy but wicked set up! like blackack said using LED's won't last long, but if you don't mind cutting the harness to fit the corners to fit into your high beams then by all means give it a shot!
Old Mar 8, 2009 | 04:56 PM
shogo2.3cl's Avatar
well i cant seem to find the turn signal write up maybe im putting in the wrong thing into the search... i duno
Old Mar 8, 2009 | 04:58 PM
shogo2.3cl's Avatar
did he put a new hole into the back of his headlight housing?
i can figure how to wire from the corner to there no problem, its just the install that has me perplexed
Old Mar 8, 2009 | 07:25 PM
DoubleSh0t's Avatar
Spencer did the re-wire for his signals, not sure if he did a write up but check it out.
Old Mar 9, 2009 | 01:39 AM
hOnU's Avatar
Da HoNu
i'm not exactly sure how he had it set up...you might want to PM him and ask him maybe??
Old Mar 10, 2010 | 05:25 PM
TGXLago97cl's Avatar
i cant seem to find the write up either, i'd like to do this to my cl
JnC
Sep 11, 2015 06:06 AM
theinsvnity
Sep 10, 2015 10:22 PM
08 NBP TL
Sep 8, 2015 08:49 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
