Question and Answer Thread
Old Jan 3, 2010 | 04:44 PM
  #441
bRunCL's Avatar
So after driving on packed in snow a couple of weeks ago after a big snow storm, my steering wheel now shakes pretty hard even at low speeds. it seems to calm down a bit around ~45 mph. This has become really annoying and it also seems the car pulls slightly to the left.(before this incident the wheel would only shake when i hit about 80 mph on the freeway) Could my alignment have gotten messed up? or any other ideas? Thankss
Old Jan 3, 2010 | 04:58 PM
  #442
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
or your wheels are unbalanced
Old Jan 4, 2010 | 03:09 AM
  #443
Gnate's Avatar
Custom User Title
I would get that checked out asap. I had a similar issue once and it turned out my wheel was about to fall off. Don't mess around with that kind of stuff.
Old Jan 4, 2010 | 08:25 AM
  #444
mitch14's Avatar
CL in lawnmower status
snow in your wheels, clean them out thoroughly at a carwash or something.
i had this issue on my subie a little while ago, it was horrible, at 80kmph (about 45 mph) the wheels were so unbalanced that the car was bouncing like a tractor. But i had a lot of it, the calipers would scrape/compact the snow so it was almost like ice when i finally got it out
Old Jan 4, 2010 | 04:37 PM
  #445
bRunCL's Avatar
Update: had the tires checked out today. According to the shop its a broken/shifted belt in the tire. They moved the wheels to the back, so I wouldnt feel the vibration in the front. I plan to deal with it for a while until I can afford a new set of tires. Kills me to replace 2 tires with decent tread.
Old Jan 4, 2010 | 06:18 PM
  #446
mitch14's Avatar
why not just look for a used tire.
that's what i did when i needed to replace one on my caddy and i was broke.
cost me 80 for a decent 17inch tire, where as brand new that size would've cost me 240 each. Just try and find a close match in tread pattern and wear
Old Jan 6, 2010 | 02:45 PM
  #447
mitch14's Avatar
anyone currently looking for JDM wheels?
Just wondering as this guy i know just got a bunch in straight from japan. Mostly staggered VIP styles, Weds, Works (vs-xx, and others), Stitchs.
Only seeing if anyone is seriously looking to get some wheels, with cash ready.
I'm pretty sure it's the same guy that aqua bought his veilsides from for a great deal.
I saw quite a few with sizes that would work with the cl, so i thought i'd try and help out my AZine brothers.
lmk asap...
if this is not the right kind of message or the right place to put this, then mods can delete it.
Old Jan 6, 2010 | 03:25 PM
  #448
(Mid-Atlantic)
I wish I had the money
Old Jan 6, 2010 | 08:43 PM
  #449
DaInFaMMuS1's Avatar
lmk asap...
Do you have any sample pics of the wheels? I'm interested in something new for my car.
Old Jan 6, 2010 | 09:08 PM
  #450
saiko_cl_duck's Avatar
lmk asap...
Just place this type of stuff in the Black Market next time please. No harm, no foul.
Old Jan 14, 2010 | 03:14 AM
  #451
rice_plz's Avatar
Car is Back
hello all
well my front struts went out so i was wondering any good places to buy new ones would be? The ones that i had on my car were kyb agx. i got my old ones from a member on here. thanks for the help.
Old Jan 14, 2010 | 08:22 AM
  #452
(Mid-Atlantic)
Ebay
Old Jan 22, 2010 | 11:28 PM
  #453
4298CL's Avatar
does anyone know where i can get a California legal catalytic converter for a 99 cl? my check engine light came on and said converter has problem.
Old Jan 23, 2010 | 01:52 AM
  #454
(Mid-Atlantic)
ebay has oem replacements
Old Jan 23, 2010 | 11:55 AM
  #455
bRunCL's Avatar
I had the same problem on my 99, code p0420, had it replaced at a shop with an aftermarket direct bolt on replacement and the code kept coming back. From my experience these cars are very sensitive at detecting emissions, my new converter worked fine, but apparently not up to the cars oem specs.
Old Jan 25, 2010 | 09:50 PM
  #456
1slo23's Avatar
Runs on Dunkin
I've been hearing a loud skweaky sound from my front passenger side and can't seem to pin point it. I just had the axles replaced a few weeks ago, and was told that the breaks were ok so I don't think its that. It also happens sometimes when I go into reverse. Whenever I step on the breaks, the sound usually stops. I also don't think its a bearing, since that was done last year.
Old Jan 25, 2010 | 10:13 PM
  #457
(Mid-Atlantic)
stuck caliper?
Old Jan 25, 2010 | 11:15 PM
  #458
South Jersey CL's Avatar
i think your pads are shot. theres a small needle in the pad thats probably grinding on the rotor, thats whats making the grinding noise. get the pads replaced and you should be fine
Old Jan 26, 2010 | 01:37 AM
  #459
shnee's Avatar
Land of Pleasant Living
squeaking? maybe bushings?
Old Jan 26, 2010 | 08:02 AM
  #460
I'd go with this. If not, then check for stuck calipers.
Old Jan 26, 2010 | 08:36 AM
  #461
(Mid-Atlantic)
pads, calipers, then bushings, that's the order i'd take
Old Jan 26, 2010 | 11:26 AM
  #462
1slo23's Avatar
Runs on Dunkin
I'm going to call a shop today and have it checked out. I was hoping it wasn't the brakes, but oh well. What can you do
Old Jan 26, 2010 | 02:34 PM
  #463
spencer_homer's Avatar
i like acura
its your brake pads. theres a warning tab on some that can make that noise to let you know that your pads are near needing to be changed. i had the same thing. if you look at the pad, you can see the small metal tab that makes the noise once they are worn down to a certain point
Old Jan 26, 2010 | 03:15 PM
  #464
shnee's Avatar
If it is more of a screeching noise, like the sound of metal on metal, it is probably your brake pads. But when you say squeak, I think more of a rubber sound. Also, you said you had the brakes checked recently and they were fine?
Old Jan 26, 2010 | 06:42 PM
  #465
1slo23's Avatar
Runs on Dunkin
Its weird, I hear a screeching sound when I go into reverse (not touching the brakes) and a squeaking sound when I'm just driving. When driving, the sound goes away when I tap the brakes.....so it certainly could be a locked caliper or pads, but I'm not sure. And again, its only coming from the front passenger side
Old Jan 26, 2010 | 07:18 PM
  #466
mattastick's Avatar
From that description, it sounds like a caliper. I had the driver's rear caliper seize on me. That was a fun repair. I'd get the brakes checked out asap.
Old Jan 28, 2010 | 05:09 PM
  #467
starboy2nv's Avatar
First EVER K24 Turbo CL
mitch, whats up with the wheels?
Old Jan 28, 2010 | 06:49 PM
  #468
1slo23's Avatar
Runs on Dunkin
Turned out i was the brakes, I dropped it off this afternoon to get done
Old Jan 28, 2010 | 10:15 PM
  #469
Kyanite's Avatar
Stay Low Pro Kinfolk
So I just popped in all my new LEDs I got in the mail today. I got license plate, top/bottom corners, turn signal, and back up ones.
Only problem Is that I can't figure out how to throw the resistor into the wire mesh in the turn signals. Where does the splice tap go and connect to? Website I ordered from had some pretty shady install instructions, and said that I did not have to cut my cables. Ima try again tomorrow in daylight, if anybody knows how or what I'm talkin bout, lemme know, thanks.
Old Jan 29, 2010 | 03:07 PM
  #470
Kyanite's Avatar
^ Forget that. I figured it out cuz im a boss. lol. Went through the taillight to get to cables. Also found out the splice tap opens even more to get the cable inside of it. I thought i had to take the cable out of its socket at first. Rofl. im dumb. My turn signals are beast now
Old Jan 30, 2010 | 08:45 AM
  #471
(Mid-Atlantic)
which splice taps did you use?
Old Jan 30, 2010 | 09:08 AM
  #472
Can you show us a picture of this?
Old Jan 30, 2010 | 11:46 AM
  #473
pics or it didnt happen
Old Jan 30, 2010 | 02:07 PM
  #474
Kyanite's Avatar
These taps. I looked at turn signal wire colors and matched the two (ground and signal) to the little box thing with cables in it. Then wrapped the taps around cables with resistor end attached to it and sealed em up.
Then here's what it looks like in full. I ghetto rigged the resistor. Taped it's black cables to metal with electrical tape. Blackack said the resistors get hot, so I didn't want em touching the foam, carpet, or other cables.
Old Feb 1, 2010 | 02:12 PM
  #475
shnee's Avatar
Let's say I want to hook up fog lights to the 98-99 fog light switch.
I have a 97 with the console conversion, so I don't think I have any of the fog light wiring.
If I buy a fog light wiring kit off ebay or where ever, could I cut off the switch included in the kit, and just connect the + and - wires to the back of the fog switch?
I haven't taken a look at the back of it, but I'm assuming connecting the wires like that would work.
Is there a reason that wouldn't work?
Old Feb 1, 2010 | 02:33 PM
  #476
(Mid-Atlantic)
anyone have a dark grey trunk carpet they're not using?
Old Feb 2, 2010 | 01:31 PM
  #477
Myxomatosis's Avatar
no, but I have random happy news for my car. It seems the government is handing out huge tax credits this year and my poor CL will be the first beneficiary.
So to sum up this month she'll be getting at the very least, some new rubber, new bushings, timing belt, axles, radiator and maybe get my drivers door repainted (keyed by random idiot). I'm so freaking happy, last week it seemed she was going to die from a lack of funding. than pay off damn near all my debt, and set aside money.
thank you uncle sam
Old Feb 2, 2010 | 02:32 PM
  #478
shnee's Avatar
Welp, I just ordered fogs.. so I guess I may find out soon enough. It would be nice if anyone had some knowledge about this though.
Old Feb 2, 2010 | 02:36 PM
  #479
correct me if im wrong but dont all CLs have the fog light wiring?
Old Feb 2, 2010 | 02:40 PM
  #480
shnee's Avatar
What I've gathered from old threads is that the 97s are not wired for fogs. I think I would need another + connection if I want the button light to illuminate, but I really don't care about that. I just want to be able to use the factory switch instead of the cheesy button that comes with it.
