Question and Answer Thread
Old Nov 3, 2009 | 01:44 AM
  #361
hOnU's Avatar
Da HoNu
can anyone tell me the difference between running:
18x7.5 +48
and
18x7.5 +35
TIA
Old Nov 3, 2009 | 08:16 AM
  #362
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
The offset
Old Nov 3, 2009 | 09:54 AM
  #363
hOnU's Avatar
Da HoNu
haha thanks chris. but is there a difference in the look on the car between a +35 and +48?
Old Nov 3, 2009 | 04:25 PM
  #364
GhettoNinja06's Avatar
Skuuuurrrrrt!
Yup, the offset.
The wheel should stick out a little more from my understanding. I could be wrong though because I haven't been looking into wheels since I had money like 2 summers ago haha.
Old Nov 3, 2009 | 10:57 PM
  #365
incredulous1's Avatar
with +35, the wheels will stick out more than they do +48. +48 is around stock, so if your trying to get it to look more flush or something, go with +35. if it rubs your fender, you can always get dennis to roll it.
Old Nov 3, 2009 | 11:31 PM
  #366
Skuuuurrrrrt!
Yup, the 35+ would stick out more.
Old Nov 4, 2009 | 01:11 AM
  #367
hOnU's Avatar
Da HoNu
thanks guys..if anything then i'll go with the +48 if i can..
Old Nov 4, 2009 | 03:21 PM
  #368
mitch14's Avatar
CL in lawnmower status
go with 35, it will give you more lip, and on a 7.5 inch wide rim, you shouldn't have to worry about that kinda offset at all
+48 would be too sunken in IMO
Old Nov 4, 2009 | 05:19 PM
  #369
hOnU's Avatar
Da HoNu
if i go with a +35 will i have to end up rolling fenders and worry about rubbing?
Old Nov 4, 2009 | 08:15 PM
  #370
i dont think you will have to worry that much. its only pushed out a little more there might be a small chance you'll rub but i highly doubt it.
Old Nov 4, 2009 | 09:47 PM
  #371
mitch14's Avatar
flip rolled his rears, but he has 9 inch wide rears, and i think runs low 30's to high 20's positive offset.... so you won't be anywhere close to that
Old Nov 7, 2009 | 12:23 AM
  #372
im given a chance to buy a f22a1 longblock for 100$. this could be great for a turbo build and i could just build this engine while i have the vtec one in my CL. should i go for it?
Old Nov 7, 2009 | 01:06 AM
  #373
hOnU's Avatar
Da HoNu
sure why not?
Old Nov 8, 2009 | 10:06 AM
  #374
South Jersey CL's Avatar
whenever i turn on the heat, the car rattles some from the engine. especially when i excellerate with little throttle, she shakes pretty good. is it the motor mounts?
Old Nov 10, 2009 | 01:47 PM
  #375
Cocoa's Avatar
2600lb CL
18x7.5 +48
and
18x7.5 +35
TIA
The rim with the +35 offset will sit 13mm further out than the rim with the +48 offset.
Old Nov 10, 2009 | 02:01 PM
  #376
1slo23's Avatar
Runs on Dunkin
I;ve been hearing a rattling sound behind my dash when the fan is running, anyone else ever hear this? Its really annoying, rattly and buzzy like the fan is hitting something while its spins...idk
Old Nov 10, 2009 | 02:35 PM
  #377
(Mid-Atlantic)
sounds like your heater core is on it's way out
Old Nov 10, 2009 | 05:16 PM
  #378
1slo23's Avatar
Runs on Dunkin
That sucks, I really cannot afford anything right now. It only seems to happen when its really cold out too, the same thing happened with my two previous Acura's. It sucks being a broke college student.
Old Nov 10, 2009 | 08:28 PM
  #379
Cocoa's Avatar
2600lb CL
Wish I kept mine, otherwise I would have given it to you for free. I threw everything in the trash that I took off the car.
Old Nov 11, 2009 | 02:58 PM
  #380
mitch14's Avatar
prolly sounds exactly like mine did, it's your blower motor, only replaceable, not fixable, take a look at the video of mine and tell me if it sounds close to the same https://acurazine.com/forums/1g-cl-problems-fixes-71/fan-problem-696050/
edit: i just checked ebay and they seem to start around 50 bucks, not bad, i paid over 100 for mine
Old Nov 11, 2009 | 04:00 PM
  #381
(Mid-Atlantic)
yeah u def can get one for around 50
Old Nov 11, 2009 | 08:03 PM
  #382
1slo23's Avatar
Runs on Dunkin
Originally Posted by mitch14
prolly sounds exactly like mine did, it's your blower motor, only replaceable, not fixable, take a look at the video of mine and tell me if it sounds close to the same https://acurazine.com/forums/showthread.php?t=696050
Yeah that sounds like it, not quite that loud though. Thanks for the help
Old Nov 11, 2009 | 08:11 PM
  #383
mitch14's Avatar
yeah mine was quiet when it started, but it gets worse with time...
but on the good side it's a bearing issue or something, so you can't really screw anything else up, just the motor itself
if you have any other questions, just bump that thread of mine, and i'll answer any questions i can, and i did the replacement myself btw
Old Nov 19, 2009 | 03:32 PM
  #384
Miiike's Avatar
Does anyone know if the rear motor mount on the 4cyl CL's is supposed to be the same on the automatics and manuals?
On 5th gen accords i believe the auto one is a little bit taller, but I grabbed one from a 5spd CL and it looks the same as the auto
Old Nov 19, 2009 | 04:23 PM
  #385
Gnate's Avatar
Custom User Title
With the right wiring harness, will the OEM CL headunit fit into a 96 civic?
Old Nov 19, 2009 | 05:59 PM
  #386
mattastick's Avatar
With the right harness, it should... Not saying anything for sure though...
Old Nov 20, 2009 | 08:36 AM
  #387
(Mid-Atlantic)
yes, as long as it's not the bose with the amp
Old Nov 20, 2009 | 01:31 PM
  #388
Gnate's Avatar
Custom User Title
I can't find that thread about taking out the whole dash. I've got everything moving, but I think I can't pull it out because of the passenger airbag, how do I get it out!?
Old Nov 20, 2009 | 01:46 PM
  #389
(Mid-Atlantic)
Airbag? For the radio? You shouldn't have to deal with the airbag, there are screws on each side of the console under the steering wheel cowling and the glove box, nothing near the airbag
Old Nov 20, 2009 | 02:02 PM
  #390
Gnate's Avatar
Custom User Title
lol no, i'm selling the dashboard.
Old Nov 28, 2009 | 09:15 PM
  #391
ljohnson02's Avatar
5th Gear
I picked up a 99 CL V6, with the typical transmission problems. Will the 05 TL transmission fit the Acura CL 3.0 V6 engine? From what I read it isn't suppose to have the issues of the previous V6 transmissions.
Old Nov 30, 2009 | 08:11 AM
  #392
(Mid-Atlantic)
Nope, won't fit.
Old Dec 1, 2009 | 09:28 AM
  #393
DoubleSh0t's Avatar
I've had a tapping noise while the car is in park or neutral that goes away when it's in any of the drive gears. I didn't think valve taps mattered on the gear the car was in? Any ideas? No other unusual noises that I can hear.
Old Dec 1, 2009 | 11:16 AM
  #394
DoubleSh0t's Avatar
Just wanted to add that the tapping noise is there even when he engine is warm.
Old Dec 2, 2009 | 12:08 AM
  #395
mattastick's Avatar
Anyone know if our rocker panels are hollow or solid? Also, is there any way to stuff anything through them? Something like this on my buddy's Saturn:
I need to run 4 pieces of 1/0 wire through the car, from the engine bay (stock battery location) to the trunk for my additional battery bank.
So, does anyone know?
Old Dec 2, 2009 | 01:46 AM
  #396
Miiike's Avatar
i think it kind of is...it looks like this when it's off the car
Old Dec 2, 2009 | 02:02 AM
  #397
mattastick's Avatar
Cool. Now, how'd you get it off of the car? Are there just clips or something on the bottom of it that hold it on? Also, do you think there'd be room in there to stuff 2 (or hopefully 4) pieces of wire that are the size of your thumb?
Old Dec 2, 2009 | 08:37 AM
  #398
(Mid-Atlantic)
Yep, should be clips all the way down as far as I know
Old Dec 2, 2009 | 09:20 AM
  #399
mattastick's Avatar
Thanks guys. I probably won't have any time to look at it till next week. Although next week, I should have another vehicle to drive daily, which will be very nice... I'll post pics of it when I get home this weekend. It's far from the prettiest thing in the world, but last time I drove it, I was getting 35mpg across town...
Old Dec 3, 2009 | 08:07 AM
  #400
ljohnson02's Avatar
5th Gear
Nope, won't fit.
Why would you say it won't fit?
