Problems Starting. HELP!
Old Aug 15, 2005 | 11:48 PM
krazy99cl's Avatar
O.G.
Hey guys....i have a problem starting up my car in the morning....or if i dont run it every 5 or so hours.....turned it to ACC...has light(normal), but when it comes to starting it, the car seems like its choking.....checked my battery at kragens. its fine(but i could be wrong). i have to jump start it by going down the driveway.
checked_
spark plugs...ok
distributor- dunno
battery- ok
please help me. thanks in advance!
Old Aug 16, 2005 | 12:02 AM
wilp99's Avatar
bad ground somewhere or bad starter.. it starts fine by push starting it?
ajtcl's Avatar
Peace, Love & Acura
So are you saying it is hard starting as in... it turns over slowly, or barely turns? If it will start by rolling down a hill, yolu probably have a bad starter... or starter relay. You might start by checking the ground for the starter. if that is good, move to the starter relay and the starter itself. If I am off track here, I apologize, but that is what it sounds like you are saying.
Old Aug 16, 2005 | 12:04 AM
ajtcl's Avatar
Peace, Love & Acura
wilp99... great minds... that shit is earie man.
Old Aug 16, 2005 | 12:18 AM
wilp99's Avatar
hell yea..im a goddamn genius.
Old Aug 16, 2005 | 01:15 AM
saiko_cl_duck's Avatar
as a cheap try, have your battery rechecked.....mine for my truck was doing some of the same funky sh*t and when they hooked up the battery they said "it's good". well i had them hook it up again and watched the volts when it sat there connected.....when its not being used it's at 12.8, but when you start your vehicle, it goes to about 10.0 to 10.6 volts...well, mine dropped to 10.0 and they said "see, it's good!"...dumba$$ didn't watch it for the whole time and it dropped to 9.2, then 8.9, so on and so on. So maybe have it checked again?
Old Aug 16, 2005 | 02:58 AM
krazy99cl's Avatar
O.G.
thats great you guys....ill try that and ill update you guys. thanks a whole lot....
another thing too..when i checked my spark plugs...the seals looks busted again.....the rings for the head/spark plugs... cut myself trying to take those off the last time.
Old Aug 16, 2005 | 10:25 PM
ajtcl's Avatar
Peace, Love & Acura
Huh?
Old Aug 17, 2005 | 03:49 PM
wilp99's Avatar
you dont take those off. they come with new sparkplugs. and they actually shouldnt be able to be removed.
Old Aug 17, 2005 | 03:58 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Old Aug 17, 2005 | 09:44 PM
ajtcl's Avatar
Peace, Love & Acura
I can't beleive he was taking those off. That is fucked up.
Old Aug 17, 2005 | 11:23 PM
wilp99's Avatar
thats how you learn...
Old Aug 18, 2005 | 08:15 PM
krazy99cl's Avatar
O.G.
what are you guys talking about....was talking about the seals on the valve cover itself....the four rings seals under the valve cover....
Old Aug 19, 2005 | 12:02 AM
ajtcl's Avatar
Peace, Love & Acura
You took off the valve cover to change your plugs? Why? You just use an 8" extension with a speed wrench, or a torque wrench.
Old Aug 19, 2005 | 02:36 PM
wilp99's Avatar
and how the hell did you cut yourself on a rubber gasket?
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
