How to install window Regulator???
Old Mar 2, 2004 | 12:33 AM
blackacura54's Avatar
fist of all dont tell me to search for the instructions cause I have for 30mins. I have seen it on here before but the search isnt working! and that sucks. MIne went out and I just bought another one and I want to save some money and install it myself. Can anyone tell me how to do this
Old Mar 2, 2004 | 01:29 AM
dennis's Avatar
It's not too hard. First take the door panel off. If you can't figure it out, then you should let someone else install your window regulator for you. After the door panel is off, disconnect all the wires (i.e. door light, window lock, power mirror, etc.). After the door is completely off, there's 3 bolts that hold the window motor. There are also 4 (maybe 6) bolts holding the long regulator. Unscrew those bolts (10mm I think) with a socket. After those are off, replace the new regulator is the big hole near above the 6.5" speaker. You may have to pull some of that white plastic off the door, it's okay, you're not going to hurt anything. Just replace the bolts and reconnect the power to the motor and give it a crank. It should work fine. If it feels sluggish, spray some lubricant along the sills before you put the door back on.
There may be a couple steps that I left out but it's been awhile since I've had to replace mine. If you have anymore questions, just ask and I'll do my best to answer them.
Old Mar 2, 2004 | 10:24 PM
martik's Avatar
Make sure you remove the 2 screws holding the door handle/lock so you can easily remove the panel. The panel must be lifted up over the top door lip and a floating door handle makes this 10x easier.
Old Mar 4, 2004 | 07:47 PM
thanks
appreciate your helps guys. I installed the regulator today the window just flies up and down! I like it to much I think i should get one for the passenger window too cause its slow as hell!
Old Mar 4, 2004 | 10:26 PM
Chinisimo's Avatar
i heard it's really hard to get to. is this the case for you?
Old Mar 5, 2004 | 12:33 AM
martik's Avatar
Re: thanks
Keep it (rails and cable) lubricated with lithium grease and it should last longer.
Old Mar 5, 2004 | 02:35 AM
dennis's Avatar
Just spray everything dude.
Old Mar 5, 2004 | 10:24 AM
HOw do you grease the cables without taking everything apart??
Old Mar 5, 2004 | 10:25 AM
nah its not that hard to get to except im 6'9 im a basketball player and I got really huge hands, but someone with normal size hands can do it easy
Old Mar 5, 2004 | 01:07 PM
martik's Avatar
Long stick or brush, then cover exposed cable in grease, move the window up an inch and repeat. But the rails probably need the panel removed to do a good job, which takes a 1/2 hour to re and re. Remember to firstly remove the 2 screws holding down the handle/lock assembly.
TLDude876
Dec 28, 2016 03:18 PM
BoricuaTL
Apr 8, 2016 01:08 PM
NBP_BALLER
Sep 23, 2015 08:18 PM
TxRzrBk
Sep 17, 2015 01:07 PM
ahsm
Sep 9, 2015 08:35 AM
