gotta quick tag removal question
I'm planning on taking the tags off my trunk except for the ac logo. I know that they're just glued on somehow, but what will take it off with the least mess and/or cleanest look
Use a blow dryer to heat up the glue, then use dental floss to get the badge off. The residue comes off well with goo gone and some rubbing. Sometimes you have "ghosting" left from the badges, but you can just wet sand that, or polish/whatever.
DO NOT USE A RAZOR BLADE
use fishing line in a sawing motion, then use a credit card that u don't want or some old drivers license or something to scrape at the glue. Goo gone really helps break up the glue, just don't leave it on your paint or it'll eat the clear coat. After that, wash the excess glue off, and then wax with some rubbing compound
yeah definitely DO NOT use a razor blade. i just did mine with an old card, and a buffer, goo gone, rubbing compound and wax to finish it. worked out perfectly, zero ghosting. did the same thing to a couple of my friends cars too, it never fails.
Originally Posted by Rane_kn
Cool just double checking before I jumped into a mess. Thanks. A lot imma go with the razor blaid and polish it up with some wax. Thanks guys this site's pimp status
btw: i like your avatar, reminds me of a few guys i've flown with in the past.
Originally Posted by SwervinCL
A razor blade... WTF.... Seriously... I can just see the next post.
"I took the advice of using a razor blade and I fucked up my paint, I dont know what to do now, Im so pissed.."
Agreed, just give it a day. They make plastic razor blades just for this very purpose, go pick some up at the parts store. Why run the risk of shaving off a few layers of clear?
use the floss cuz ur putting yourself at risk of scratching ur paint or putting a nic in it just be sure to use a good polish if u have ghosting. start out with something that is less abrasive polish and if that doesnt work than use something a little stronger and finish it up with a good wax and you should be good
cycdaniel
Dec 17, 2019 10:58 AM
gotta keep waxing today!
