engine swap
engine swap
i was wondering if i could swap my j30 to an 09 Rl j37 or 07 MDX? tried searching it and couldnt find jack about it...so i was jus wondering will it work and what kind of tranny do i need for it...so u guys opinion on it....
i have the money...im asking is do i have to buy new mounts and what kind of tranny...cuz i want to have atleast 300hp or even more wid a lil bolt on....cuz the j30 200hp wid bolt on is still kinda sluggish idk....
I hope you have shit loads of money, because a swap like that is nowhere, even remotely close to cheap.
It's not like doing an h22 swap.
i want to swap my j30 for an j37...i have an friend dat has an shop that has an wrecked Rl that has the j37 and i swap my j30 for the j37 engine....so yea i wonder if its an direct bolt or wat...oh yea has anybody done a mid-muffler delete or 1st gen cl? or do we even have an mid-muffler....bcuz i want to take out my mid-muffler if we even have wun and just weld an 2.5 pipe to the oem muffler...i wonder how it would sound....
lawlz at direct bolt. No. Maybe it's just me but i'm assuming with all the custom fabbing that would be required, you could look to spend a minimum of around $3-4 thousand, maybe even more
check out online, google man, i'm lookin for info on a j35 swap. the j37 has high potential, from what i've read...but there are some problems right now for it. So far, the j35 seems pretty good. I plan on a j35a3 block with a j32a2 head with RL pistons...look it up, it's being done as we speak
Last edited by a2ndragoon89; Jan 31, 2009 at 07:17 PM. Reason: changed the web thingy
to me it would seem that this swap would be way too complicated and end up costing you big $$$. Like it probably could be done, but with an engine that just came out there would be less info and aftermarket parts to back it up. Plus the vehicles which currently contain that engine are both AWD
. Seems like way too much of a headache IMO, but there's only one way to find out if it'll work, try it yourself
j35 uses the same mounts as a j30, I have not seen anything about the j37 though. Pretty sure the mounts are all different, I know the new TL 3.5's are different
not worth the time & money it'll cost you cuz it'll all be custom..
if you got money to spend just go with the j35 w/ the CL-S 6 speed tranny, its been done & you wont be dissapointed..
^all you would need is the 3.0 subframe w/ 6th gen v6 accords mounts (i think the tranny mount has to be custom) & you shouldn't have an issue, maybe hood clearance if anything..
yeah i've looked into it
If by mid muffler you mean the resonator....have at it, it's been done.
As for the swap, no it hasn't been done with that engine. If you have the money, the engine, and the shop that can do it, then get started on it. That way we can see another swapped J series in the crowd.
dirtyspitshine
Jan 3, 2023 08:23 PM
LECKEY73
Feb 22, 2016 01:32 PM
justin7779
Dec 25, 2015 10:33 PM
That's gonna be the biggest pain
