Emergency Brake Light
i want a bimmer =(
alright guys, i got a question for you.
The past two mornings when i have started my car my e-brake light came on and stayed on the whole way to work...but the e-brake WAS NOT and had not previously been in use...BUT in the afternoon when i leave work i start my car and the light doesn't stay on, it goes away, like it should...
anyone....anyone....bueller...bueller??
thanky..any thoughts/suggestions will be greatly appreciated fellas
i want a bimmer =(
lol...just a lil off topic..
i got all excited cuz i thought someone was gonna tell me what was wrong w/ my car..haha
but the song is either #9 or #10..when my friend burned the CD for me she thinks she may have missed a song, but it's #9 on my CD
funny thing was, when i had my acccord, i never noticed he said that, but the 1st time i listened to it after i got my CL, i caught it immediately..
The CL is wierd. If your break fluid is ever so slightly low, the brake light will come on. Mine wasn't even below the line, actually slightly above the line but filled it with more and the damn light disappeared. Try that.
Swaps? $3000 for 50HP? :(
Careful. Just adding fluid will push your pads past their rivets into the rotors.
The level is low because your pads are worn.
Take a look at the pads before going any further.
i had same problem ..... check your calliper .... in my case it was a rear driver side. Break calliper....rubber got old and break flued was leaking out. I had e-break light coming up and then ABS light too.
HOOK EM HORNS
i had the same issue on my '99 2.3, it seems like it only happened when it was cold,, but it comes and goes,(but not too often since Spring came)???????????
got the same problem here. In the morning my light will come on when I start the car (but only when its below 70 degrees out or it was cold the night before) and then it goes out after an 15 minutes or sometimes takes half the day. Fluid is above the line, checked and the pads are fine, talked to the guy at the dealer and he said that it might just be a faulty sensor but I dunno. never does it in warm weather though.
i want a bimmer =(
yeah funny some of you mention the whole "cold weather" gimmick...I've had the CL a little over a month now and the only time it's happened has been the past 2 mornings, it also just happend to be freezing ass cold too.
but i have also noticied that my brake's have been squeaking, not ALL the time, but when it's damp or like 1 or 2 a.m. and i'm driving back from where ever i've been that night.
so maybe dropping it off at the dealership wouldnt be a bad idea, just to have them check it out...although if it's normal wear & tear the warranty prolly wont cover it.
oh well...i'll get over it
I had a problem similar to what you're all describing. Had it at the shop and they found the brake fluid level sensor was faulty. And to think I was about to spend money on some black electrical tape to cover it up...
rockyboy
08-04-2024 10:35 AM
mada51589
05-03-2022 08:54 PM
