Do I have a problem??
Old Jul 10, 2004 | 09:09 AM
Acura2.3CL's Avatar
Lately I have noticed that I can slide most of the gears out of gear w/out using the clutch (no grinding). I am pretty sure that this can not be good, but do I have a problem. Is my clutch going to go soon? Thanks!
Old Jul 10, 2004 | 09:13 AM
liloj's Avatar
i like orange juice
like shifting gears? or just throwing it into nuetral?
Old Jul 10, 2004 | 09:46 AM
powderman's Avatar
my friend shifts his volvo 850 without using the clutch (out and into gears) i'm sure there isnt a problem, just might not be the best thing for the car to do it also, someone on here will probably tell you why, but it takes a certain rpm to slide the gears out without the clutch
Old Jul 10, 2004 | 12:11 PM
xrunner86x's Avatar
A-CL Totaled Member
if youre at the right rpm you can shift in and out of gear, but its a lot better on your gears to use the clutch
Old Jul 10, 2004 | 02:27 PM
98AcuraCLpimp's Avatar
yaq, you can do the same shit w/ motorcycles
Old Jul 11, 2004 | 08:51 AM
Acura2.3CL's Avatar
Sorry, I think I explained it a little wrong. The car istn doing it...[B]I am able to push out of some gears w/out the clutch. I have also heard about shifting w/out the clutch at certain RPMs and that might be it. I guess there is no real problem. Thanks for all the help!
Old Jul 11, 2004 | 09:56 AM
proaudio22's Avatar
-S namyaC-
We do it with the big trucks (24', semi) all the time. Like for accelerating, just push into neutral and with a slight pressure on the next gear. Let off the gas and when the RPMs fall to the right place, it'll just slide into gear, then step on the gas. Not quite as easy downshifting, but it can be done.
Of course, we're only talking about 500-2500rpm in trucks like that.
On any car tho, there shouldn't be grinding coming out of a gear. It's going into the next that would produce the usual sound of meshing gear teeth.
Old Jul 12, 2004 | 10:18 AM
Acura2.3CL's Avatar
thanks a lot proaudio22
Old Jul 12, 2004 | 04:27 PM
wilp99's Avatar
theres no problem......yet. if u keep doin it it will tear up ur syncromesh inside the tranny they get hung up. and u WILL bend a fork. that means rebuild and not just a clutch.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
