clutch squeakin ???
fellow MASShole
clutch squeakin ???
just noticed that the clutch is squeakin ... kinda loud actually its comin from underneath the car its not at the pedal ??? just need lube or what ? warranty??
MaCe
MaCe
Not Registered
Does yours squeek when depressed or all the time? My clutch sounds like a bunch of crickets chirping, but just the slightest pressure on the clutch pedal and it stops. My throw out bearing is causing my noise, because of the clutch is vibrating slightly.
Turn Signals are good!
does it squeak when you push on or let off the pedal... or is it when you start to engage the clutch??
If its with the pedal movement, your slave cylinder may be going bad ($20 to replace) or it could just be squeaking where the slave cylinder piston meets the arm.
If its squeaking when you start to engage the clutch, it may be getting close to time for a new clutch.
BTW mace, where in mass do u live?
fellow MASShole
it squeaks when i push it in .. like midway threw the motion
not liking the new clutch notion ... dont fell like droppin 500 on a new clutch
im in western mass ... springfield area about 1 1/2 hours from albany
MaCe
MaCe
my accord did that too, its the arm that connects the slave cylinder to the clutch assembly... I sprayed wd-40 on the arm where it meets the slave cylinder... and it stopped squeaking... that was like a month ago and still no squeaking.
Originally posted by Limmerz
Mine's doing the exact same thing as you Mace...where did you spray??? Did you just go under the dash and spray upwards or did you have to go under the car???
Atl/Mia reppin'
I'm curious as well...i have some squeaking when I depress the clutch...of course i only hear it before I turn the car on (since my radio is usually playing too loud )
fellow MASShole
well i got some bad news ... it wasnt squeakin after i put it on but when i drove home tonight from work its still makin noise ... and its when i release the clutch not when i push it in ... i sprayed where SomeKid mentioned and i little bit inside the car as well ..... just looks like im gunna have to bring her in to get checked out i'll keep ya posted on the info
MaCe
MaCe
theres a pivot point for that arm, inside the clutch housing (just inside that rubber boot) where it may be squeaking from. I dont recomend spraying in there though, if it gets on the clutch you will probably have some slipping issues.
SidhuSaaB
05-30-2020 12:40 AM
