Check Engine Light question..
Old May 23, 2005 | 06:29 PM
Ram's Avatar
Ram
Question Check Engine Light question..
i scanned the car computer and the code that came up was P0401 EGR Flow Insufficient.. what does that mean?? that its just needs cleaning or has it gone bad?? i was thinking of just getting another new or used one from another CL or 94-97 Accord.. let me know what u guys think i should do?
Thanks in advance for ur help..
Ram
Old May 23, 2005 | 09:32 PM
endlessdragon's Avatar
~ The Endless One ~
means u gotta change your EGR valve...it'll run u about $300 unless your car is still covered by the service warranty extension...take it to acura
Old May 24, 2005 | 12:07 AM
Ram's Avatar
Ram
thanx Dragon..
this car is killing me on expenses..last week just got a new timing belt, water pump and the works for $475...now this and still need a new muffler.. thanx tho..
Old May 24, 2005 | 12:29 AM
wilp99's Avatar
what year and how many miles do you have. 97's i think are covered for like 150k miles and the 98/99's are covered for 100k for the emissions extension.
also do you have a 3.0 or 2.x...
eather way the egr valve is prolly still good you just have to take off the intake maniflod and clean out all the carbon in the egr paths.
Old May 24, 2005 | 11:22 PM
Clman02's Avatar
h22
Old May 25, 2005 | 01:10 PM
Ram's Avatar
Ram
mine is a 97, but i'm at 166k miles..i called the dealer and he said to take off the engine cover and clean out the ports..so i'm gonna check that out today and see what i can do..i cleaned the egr valve yesterday, and still the same reading on the OBD-II reader.. thanx for the help..i'll let u know what happens after i try to clean the ports..
Old May 26, 2005 | 12:26 AM
wilp99's Avatar
did you reset the code? if you dont reset the code it will not just go away just because you fixed the problem.
Old May 26, 2005 | 01:12 AM
Ram's Avatar
Ram
i called acura today and they said that the egr ports are probably clogged and need to be cleaned.. so tomorrow i'm taking it to a local shop and they are gonna clean them for me..then they will turn the light off.. thanx and keep u informed..
Old May 26, 2005 | 11:37 AM
wilp99's Avatar
dogg thats like 300$... well i guess if its done right.
Old May 26, 2005 | 11:56 AM
ajtcl's Avatar
Peace, Love & Acura
Nah, my mechanic friend would do it for $30.
Old May 26, 2005 | 04:11 PM
Ram's Avatar
Ram
ok got it done.. it runs a little better.. pick up is better, but still not that great..the shop here f'ed it all up at first and said nothing was wrong...the car was shaking, cluster guages were shaking, car shut off on me twice and then once i got home the check engine light came back on and this time it read, PO301 which is Cylinder 1 misfired.. i called them up, pissed like crazy.. got back there, they looked at it after i spend $150 to get it fixed, then said," yeah one of ur spark plugs was not back in all the way, so ur lucky that we didnt charge u for that one spark plug.." in my mind i said "i'm lucky?!?!?" they are lucky i'm not ready to kick some azzzz then sue them.. man i'm still pissed..on top of that, they said have a good day..yeah right..i dropped the car off at 815am..said it'd take 1-1 1/2 hrs to fix..took 6 hours.. then made me late for work.. sorry for the rambling but i had to get this off my chest.. thanx guys..and good luck w/ urs if u need this done.. deep breath.. whewwwwwwwwww!! haha.
Old May 27, 2005 | 09:58 AM
Ram's Avatar
Ram
now again another CEL on again.. this time 3 problems.. PO301 & 302 which are Cylinder 1 & 2 misfire and P1300 which is an Ignition malfunction...man i'm sooooooooo ready to sue..
Old May 27, 2005 | 10:51 AM
Chemmech's Avatar
Wow!!! Never heard of a code 1300, those Jackoffs messed your car up . I would not go back to that place if I were you.
Old May 28, 2005 | 12:02 AM
Ram's Avatar
Ram
i went to them this morning..they said what they did w/ the EGR is basically cleaned it out like we all do it..w/ the carb cleaner, so they did right i guess...now my luck being soo bad, these codes came on..i took it to a place i trust more and they fixed it all for me for $200..the PO301 & P0302 are Cylinder 1 and 2 misfires..cuz the fuel rail needs cleaning and the ports for the fuel to go thru from the rail to the cylinders were clogged..only 2 showed up on computer, but when opened up, there where 3 clogged.. and the P1300 was a computer misfire due to 301/302..now everything is cleaned and fixed.. after $350 spent, it better all be cleaned up!!!!!!!!!! now left is a new muffler, and i'm done.. i hope.. crossing fingers.. thanx to everyone for the help and comments.. later..
Old May 28, 2005 | 03:25 AM
Hobo's Avatar
Flap.
the egr doesnt get cleaned with carb cleaner, should have gone to the dealer, the carbon deposits need to be drilled out and the egr replaced.
Old May 28, 2005 | 01:10 PM
yossi's Avatar
i took my car to the dealer, 97 cl, with 101k, and the egr code they told me its NOT covered under any kind of emissions warranty, what can i do now?
oh, this guy says he did hs timing belt and water pump for $475, is that normal? i was told by my mechanic that since i hit 100k i should do it, estimated price $1000
Old May 28, 2005 | 01:27 PM
Hobo's Avatar
Flap.
if they say its not warranty, you can try another dealer, or just suck it up and pay.
475 seems like a reasonable price for a smaller shop to do the 100k service, dealers usually charge more like 900-1000
Old May 28, 2005 | 07:23 PM
~ The Endless One ~
3 words:
sell you car
Old May 29, 2005 | 02:15 PM
Ram's Avatar
Ram
i spent all that money now..i cant sell it.. plus i may be moving from NC to the Northern VA/DC area in a month or sooo...so we'll see..i'm keeping it till its no more..too much for a new car esp. since i'm on an hourly job still..once i'm salary, then a new car..
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
