Check Engine light Blinking
Old Dec 13, 2003 | 12:03 PM
jasshopper's Avatar
Hey Radio Shack.....Relax
Does anyone know what the problem is when your check engine light is blinking? I've had it come one, but never blink...any ideas?
Old Dec 13, 2003 | 12:08 PM
Cocoa's Avatar
2600lb CL
Check your oxygen sensors. Those are the reason to why your check engine light comes on. Maybe you need new ones, maybe your cat is going out, maybe your getting too much fuel, or too little, could be anything, but you oxygen sensors detect that stuff, and cause your light to come on. How many miles does your car have?......
Old Dec 13, 2003 | 04:24 PM
legendaryCL98's Avatar
'07 November = STI
sometimes the check engine light comes on if your low on oil... i noticed that the car turns on the check engine light sometimes rather then the check oil light...
Old Dec 13, 2003 | 09:43 PM
wilp99's Avatar
is the car running ok?
Old Dec 14, 2003 | 01:02 AM
jasshopper's Avatar
its running fine...the last when the light came on, I took it to the dealership, where they told me a cylinder had some deposit run thru it and stop functioning But it seemed fine then running off 5...so it seems fine now. But after having two trannys replaced, I've come to accept having engine problems...how shitty does that sound...
Old Dec 14, 2003 | 01:01 PM
'07 November = STI
check to see if there is anything stuck under your e-brake handle thingy.. if a coin or something got jammed there, your handle might just be on top of it.. thus blinking brake light everytime u hit a bump on the road... does it blink when idle?
Old Dec 14, 2003 | 02:03 PM
atama's Avatar
8th Gear
Go to a mechanic, for $25 bucks they can tell you what codes come up. If it is the oxygen sensor, remember you have TWO oxygen sensors, one in the front, one in the back. Check both. A new uni sensor is ~ 80 bucks, dealer will charge $250 for EACH...
Old Dec 14, 2003 | 02:18 PM
dustbuster4's Avatar
A-CL Post Whore w/N2O
The check engine light came come on for MANY reasons, one of them being bad O2 sensors.
You can do the "paper clip" check to see if it throws a code: http://home.insightbb.com/~niedejb/refs2.html
Old Dec 14, 2003 | 11:20 PM
jasshopper's Avatar
Thanks Dust...this oughta be mighty helpful...although it may be my oil level...like LegendaryCL98 said...
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
