Car doesn't start, need some help.
Old Jun 20, 2007 | 07:13 PM
horsey2k's Avatar
B A N N E D
I have a 97 2.2cl. When I switch the ignition ON and start my car, it won't star. I also heard some noise from the fuse box and the dash, the noise is like a mouse clicking sound. check Battery ,it is ok. when I turn on the headlight, I can hear the mouse clicking noise from the dash and the underhood fuse box. also when I try to start my car, the dash light is turning darker. when I remove the key, and switch the iginition on again, the dash light becomes normal. All the fuse are ok. Everything was normal last night.
is it a lighting relay problem? or the starter? or battery is dead. Is it expensive to replace it? Can I do it myself? I'm not good at fixing car. thank you guys.
Old Jun 20, 2007 | 07:23 PM
horsey2k's Avatar
B A N N E D
By the way, when I turn on the headlight, the headlight never turns on. I also hear some clicking noise from the fuse box at the same time.
Old Jun 21, 2007 | 01:34 AM
legendaryCL98's Avatar
'07 November = STI
my guess is its your battery.. take your battery to a kragen or auto supply store to get it checked.. if thats not it.. get your alternator checked.. and if thats not it.. check to see all your wires are grounded right.. and if thats not it.. check your house for gophers, as they like to chew on wiring
Old Jun 21, 2007 | 02:54 AM
horsey2k's Avatar
B A N N E D
Thank you for your suggestion. I just tried jump starting my car. on the first 5 minutes, I couldn't start it. but I let the jump cable stay there for about 5 minutes, my car can start. I let my car run for about 15 minutes, then turn it off. I tried to start again, the car couldn't start, I was in the same situation. Should I change my battery? or is it another serious problem? like starter, alternator or something else.
Old Jun 21, 2007 | 04:16 AM
subbuzz's Avatar
07 tl-s in
the starter you'll have full power but it'll click and not try to turn over when you try to start, my guess is you batt is not holding a charge or your alt is not charging your batt.
Old Jun 21, 2007 | 04:23 AM
subbuzz's Avatar
07 tl-s in
try disconnecting your battery while the car is running. If the car cuts off, you need a new alternator. If it stays on, it's fine. you got any ind light's on?
Old Jun 21, 2007 | 03:03 PM
horsey2k's Avatar
B A N N E D
thank you guys, just changed the battery today, and everything is normal.
Old Jun 21, 2007 | 03:08 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Glad the battery was all it was, having a dead bat sucks, but at least it's an easy fix
Old Jun 21, 2007 | 07:37 PM
'07 November = STI
you mean to say it wasnt the gophers?! hmm.. keke, glad to hear your car is A-OK!
bearingman07936
Jan 7, 2016 03:22 PM
1lowtc
1G RDX (2007-2012)
15
Nov 19, 2015 10:52 AM
Phambam12
Sep 6, 2015 06:57 PM
jordanboi
Sep 5, 2015 01:33 AM
NSolace
Sep 3, 2015 08:02 PM
