Boost Gauge to Replace Engine Temp- DIY?
Old Jan 25, 2007 | 12:06 PM
suprachica79's Avatar
Hey guys. I've been thinking of replacing my engine temp gauge in the instrument with the boost gauge because I want to be able to look at it very quickly and I think it would be a cool sleeper look. I was wondering what I would have to do to make this work, or can it even work? Any help would be great guys. thx
Old Jan 25, 2007 | 12:13 PM
AznX TL's Avatar
where is....
it would work except the temp gauge is very very important
and you'd have to find one that would fit into the slot of the temperature gauge
Old Jan 25, 2007 | 12:25 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Finding one to fit in there would be cool, but would need to be pretty small. Also, I wouldn't give up my temp gauge after my radiator cracked. But it's a cool mod idea, g'luck chica
Old Jan 25, 2007 | 02:31 PM
well I'm going to be having some other temp gauges, and my sensor for the engine temp is broken right now anyways so I don't even use it lol. Does anyone know what size would fit there?
Old Jan 25, 2007 | 06:01 PM
Blenz's Avatar
Here's a picture I found of Will's old set-up on his 2.3CL:
I'm not sure what size those guages are but they look like they fit in there nicely.
I also think it's a little ironic that you're covering up an engine temp guage with a guage that monitors a system that puts huge amounts of extra thermal stress on your engine. I know the stock temp guage and sensor are far from being accurate but you should really think about monitoring the under hood temperatures somehow if you're covering the stock guage.
Have you put any thought into ways of reducing under hood temps once your actually running boost?
Old Jan 25, 2007 | 06:02 PM
shineynitelite's Avatar
NAWWWWSSSSSS
you'd be much much better forgeting those mounts and then siliconing them to the plastic piece that surrounds the gauges, much much cleaner look!!
Old Jan 25, 2007 | 06:21 PM
I was thinking of putting it directly into the cluster...but that looks pretty good
cycdaniel
Dec 17, 2019 10:58 AM
SpraykwoN
ILX
Sep 11, 2015 08:45 PM
iCrap
Sep 11, 2015 06:21 PM
Koff
Sep 9, 2015 02:55 PM
gqdabien
Sep 8, 2015 11:41 PM
