big problem??
big problem??
i was driving today and i was REALLY low on gas...i parked the car to go the ATM and when i got back my car wouldnt start. so i took the key out put it back and cranked it again and it started. i was pulling out of the parking space and it make a puttering noise like it was going to turn off.
usually when my tank is low it takes a few more seconds to turn the engine over.
should i be worried about this or what?
appretiate it
appretiate it
gas is expensive but, wow!!!was your low gas light on if so i wouldn't worry. i heard it take more gas to start a car. i personally never really let it go below 1/4.my car seems more retarted then normal if i i don't keep gas in it.also runnin on e isn't the best idea either cuz it picksup all the shit that leftover in the tank.
stop runnin your poor cl on fumes.
Originally Posted by saiko_cl_duck
running on fumes just isnt smart at all, fill that puppy! Most of our cars get a little squirrelly with less than 1/4 tank.
Buy some gas grasshoppah
"It ain't got no gas in it."
-Carl, Sling Blade
I like to fight the top half of the tank. I know it doesn't matter in the end, but it is easier to spend $20 than it is to spend $40. Just keep fuel in it and you will be fine.
Oh, one other purpose of staying topped off...
Keeping fuel in keeps moisture out. Moisture is your fuel system's enemy.
In addition, if a state of emergency were to happen, it is nice to know I have around 350 miles of travel rather than 10 miles.
-Carl, Sling Blade
Originally Posted by agranado
so... your tank was really low, you turned the car off, and then when you turned it on again it wouldnt turn on properly?
Nah, that is a certain exageration. But it does take more fuel to start then to run. It would be more comperable to 5 minutes of idle time as opposed to turning off the car and starting it again. If you are gonna idle longer than five minutes, turn it off.
Originally Posted by VaTECh_CL
I read somewhere that you lose 10 miles worth of gas everytime you start your car.
shut your car off and on 30 times...that should kill about the whole tank of gas if your internet web forum theory is correct.
Originally Posted by Slooo97CL
you should do a test
I bet it doesn't
appretiate it
appretiate it
10miles? i dont know about that....but it does drain more gas and battery when starting up a car. Also bad thing about drive with a low tank of gas is...once it get down to the end it a really good chance the fuel pump will suck in some dirt and other junk that built up in the tank over the year. i never let me go lower than 1/8 of the way.
Its amazing what a little 15% C4–C8 straight-chain alkanes, 25 to 40% C4–C10 branched alkanes, 10% cycloalkanes, 25% aromatics, and 10% straight-chain and cyclic alkenes will do...
thanks alot guys
i filled up and shes running fine again... never letting that shit happen again
-Carl, Sling Blade
-Carl, Sling Blade
cycdaniel
Dec 17, 2019 10:58 AM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
brandnewcolony
Sep 12, 2015 10:39 AM
