Another INtake question
Old May 13, 2004 | 08:49 PM
Sir's Avatar
Sir
CL = Can't Lose.
Does the 94-97 accord intakes fit our car perfectly-as in without need for any molding or manipulation? Or would one have to do something to the intake for it to fit exactly?
And also..I'm thinking about bidding on this:
http://cgi.ebay.com/ebaymotors/ws/eB...478197023&rd=1
I know intake questions have been asked a thousand times. Thanks for any input.
Old May 13, 2004 | 08:52 PM
DanMan1464's Avatar
Autobot
If you're already going for $160 + shippping, hit up the v2....there have been reviews about it, and say that it's worth it.
I believe that it will go in exactly without modification, considering that both cars use a f22 engine.
Dan
Old May 13, 2004 | 08:59 PM
ajbent86's Avatar
what exactly does the V2 do differntly then the standard CAI?
Old May 13, 2004 | 09:15 PM
CLScotty97's Avatar
Respect My Authoritaaa!!!
Apparently, thers a better hp boost and it sounds better, from what i hear, its worth the money, but im still debating
Old May 13, 2004 | 09:20 PM
Hobo's Avatar
Flap.
no modification nessasary... just bolt it up.
if youre going to pay ~150 for 1-3 hp and a nice sound might as well drop the extra 50 or so bucks and get 5-10 hp
Old May 13, 2004 | 09:25 PM
CLScotty97's Avatar
so if i were to buy a short ram v2, or cai intake for my 97 3.0, id just pop it right in no work needed? besides taking out the stock parts etc...
Old May 13, 2004 | 09:35 PM
DanMan1464's Avatar
Autobot
disconnect the battery
then install
then let the engine run for 10-15 mins without revving at all
this reset's the ECU for the new intake
Old May 13, 2004 | 09:42 PM
CLScotty97's Avatar
your just full of good information...
Old May 13, 2004 | 09:52 PM
LCARUCA 97's Avatar
Trailblazer = SUCK
good but not totally correct.. You need to pull the ecu fuse and the radio backup fuse (both under the hood), put em back in THEN let the car idle for a spell.
Old May 13, 2004 | 09:53 PM
wakeboardfusion's Avatar
Miss th 3.0
if we disconnect the batt will we need the radio code?
Old May 13, 2004 | 10:04 PM
CLScotty97's Avatar
I think so, some idiot guy did work on my car cuz my pops new him and just disconnecting power in general to take off the check engine light did the work, he even tried to punch some random numbers so i had to pull that old, let the radio idle for 1 hour then punch the code in... last time that guy touches my car!
Old May 14, 2004 | 12:28 AM
ju5tchi11in's Avatar
roomate has a CL too
yep
can be found in the manual or in your trunk or under the fuse box cover or on the side of the glove box or stuck somewhere else... or it might not be there at all and u have to pull out your radio and look at the serial number on the back of the radio and then call the dealer.
Old May 14, 2004 | 12:59 AM
babyloc86's Avatar
i didnt even reset mah ECU when i installed mah short ram aem intake....wut happens if u dont?
Old May 14, 2004 | 08:27 AM
LCARUCA 97's Avatar
Trailblazer = SUCK
not a big deal, it will just make your car run a tad better if you do.
Old May 15, 2004 | 02:09 PM
Sir's Avatar
Sir
CL = Can't Lose.
Thanks a lot.
cycdaniel
Dec 17, 2019 10:58 AM
hues10
1G RDX (2007-2012)
Sep 7, 2016 03:47 PM
drone619
Jan 26, 2016 07:09 PM
IlliniAcura
Sep 19, 2015 09:31 PM
datadr
Sep 12, 2015 09:12 PM
