amp question
Old Jul 21, 2005 | 05:58 PM
blackacura's Avatar
amp question
I'm kind of oblivious to what this shit means... can anyone help me out? translate "4 ohms bridged mono" into something more simple for a retard like me...? is this something i can control?... thanks for the help...
Old Jul 21, 2005 | 06:08 PM
LCARUCA 97's Avatar
Trailblazer = SUCK
ok. say you have a subwoofer that is dual voice coil and each coil is 8 ohms...(or even two 8 ohm subs). if you paralell them together the amp will see 4 ohms. 8+8 = 4, 4+4 = 2 and so on. please let us know a little more about your setup and we can be of greater help.
Old Jul 21, 2005 | 06:13 PM
blackacura's Avatar
thanks man... yeah, i got an amp, the specs say 700 watts at 4 ohms, bridged mono, i was going to get the new 12" alpine type-x subwoofer... but now that you say that, the alpine is dual 4-ohm voice coils... how much power am i gonna lose if its at 2 ohms not 4?
Old Jul 21, 2005 | 06:16 PM
klepto's Avatar
type x? go for the type-r's you can get them pretty cheap on ebay
blackacura's Avatar
http://www.sonicelectronix.com/viewi...iliate=froogle
Old Jul 21, 2005 | 06:17 PM
LCARUCA 97's Avatar
Trailblazer = SUCK
you will gain power when you reduce the ohm load. however, you may want to check and make sure that amp can handle 2ohm operation.
Old Jul 21, 2005 | 07:43 PM
Leon's Avatar
"4 ohms bridged mono" simply means when bridging ur amp you have to use a 4 ohm load or higher (6, 8...), using a 2 ohm load will cause the amp to run hot and cut off. some amps can handle 2 ohms, or even 1 or .5, but if it says "4 ohms bridged mono", 4 ohms is the lowest
Old Jul 21, 2005 | 09:54 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
4drviper
Apr 23, 2025 07:13 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
