Fuse keeps blowing
Fuse keeps blowing
2003 MDX
The fuse for the radio, the data screen and both power outlets keeps blowing (it's all the same fuse, the 15A "Front Accessory Socket" fuse). I notice that it seems to happen when the vehicle is accelerating. I have replaced the fuse at least 5 times but it only lasts ~30 - 45 seconds.
I recently replaced the cabin air filter and am wondering if I somehow might have caused a short when I was reinstalling that stupid metal bar behind the glove box.
Can anyone offer some advice before I head to the dealership?
2003 MDX
Remove the glove box and see if you have any wires touching metal or a bent wire that stopped the circuit. If you do not see anything immediately, unplug each device one by one and try to pinpoint which of the circuits (radio, data screen, or power outlets) is causing the problem. In my experience, it's usually something trivial that's causing the headaches.
Good luck and let us know how it goes...
Well thanks for the info. I looked around behind the dash and didn't see any exposed or otherwise abnormal wires. I did see one that was bent kind of weird so I straightened it and wrapped the bend in electrical tape.
I thought I had fixed it as the new fuse held for a couple of hours but it blew again. I took the car the Pep Boys and they ran a diagnostic; they seem to think that my radio is what is causing the short and recommended having it replaced.
I called Acura.... They want $1,000 plus labor for a new freakin radio....
I think i'm gonna be sick.
Moderator Alumnus
By 'trim' are you referring to the stuff around the radio? If so, it is the 'wood' trim.
Do you think that these radios able to be repaired? You think I can remove it and take it to some sort of electronics repair shop and have them look at it and fix whatever is causing the short?
Moderator Alumnus
I'm still not convinced that the radio is causing the short. Maybe get a 2nd opinion? Im not sure if the guys at Pep Boys know what they are talking about. By trim i meant options, touring, navi, res, etc..
Ok, sorry.
No Navi, no RES, and i'm pretty sure I have the touring package, but I don't know for sure. I tried to search the forums to find out what differentiates a touring from a non-touring but I keep getting an error message. So please forgive my ignorance.
I have a roof rack and running boards if that helps (lol!).
You know, I can't honestly say one way or the other with 100% certainty. However, I am almost certain that this started happening right before I changed the filter.
Mike, Pep Boys has no clue what they're doing. Years ago a friend of mine got a technician job there after taking one class in junior college (no joke). Stay clear.
I'd find a local mechanic and see what he would charge. You can try http://www.mechanicadvisor.com/ or Mechanics Files. Talk to them on the phone and see if they have the diagnostic equipment for electrical shortages.
If you're more comfortable with the dealer, I'd take the car in for an oil change (or whatever service you have coming up) to a different dealer that quoted you $250. Tell them "oh by the way..." that your fuse continues to blow and you're wasting money on fuses. If they tell you it's going to be a $250 diagnostics, I'd tell them you were hoping it would be less...usually they work with you on the price. Having other service done often helps on a diagnostic charge because the car is already in their service bay.
Check to make sure there is nothing stuck in any of the power outlets / cigar plugs. If you have anything plugged into them, unplug it and see if that fixes it. Anything conductive sitting in there will cause a short. (Think paperclip, hair pin, penny, etc)
I looked around and from what I was able to find, replacing the radio doesn't appear to be all that difficult. My only concerns are:
1) getting the correct radio if I were to order one online.
2) when I remove the radio from the console, it looks like the console screen (I don't have RES or NAVI) and the radio come out as one single unit. Will I be able to separate the radio from this single unit and then will I be able to attach the new radio without any problems?
3) I am worried that I will break the clips holding the plood (sp?) to the dash.
With those things in mind, might you have any further advice if I were to try to replace this myself?
Thanks for all your help btw.
Former Sponsor
Do you have an aftermarket alarm?
We have seen a few MDX's in here with the same sympton and the results have consistantly been a clipped wire during aftermarket alarm install.
Could be our local alarm hack in town.
Good luck & let me know if you need and wiring diag's
2003 MDX
Nope, no alarm. I'm running some trial and error for the next few days to see if it really is the radio. Fifty-five isn't convinced so i'm gonna hold off on replacing the radio until i'm absolutely sure.
Former Sponsor
Let me know if I can help.
You think it would be the radio itself or would it more likely be the wires leading to/from the radio? How can I test this? Any ideas?
Former Sponsor
I will post tomorrow w/ his contact info.
Former Sponsor
Said tech is out sick today..however, I had a middle of the night thought on this:
Unplug the radio from the harness and check if the fuse blows. If it does, it is not the radio and you can start tracing out that wiring harness.
If it doesn't blow, its then an internal fault in the radio.
Make sense?
Make sense?
Ok. My wife has been driving around with the radio turned off for two days now and the fuse is still solid.
Does this confirm that it is the radio or could it still be a wiring thing? Should I unplug the radio to test it further?
Former Sponsor
I would say yes, but it wouldn't hurt to unplug it as well.
I have a 04, having the same problem. I took out the entire Nav/Radio unit and turn the key, it still pop. I reach behind the console and jiggle all the cables(at least the one i can reach), and put the 15amp fuse back in the panel. It works for a while, then the fuse pop again...................
Ok, I just sent the car to PikesPeakAcura at Colorado Springs, they were able to identify the problem! I was surprised they were able to find the short quick. Someone inserted coin into the DVD player, thus caused a direct short. They told me they have to take out the DVD player , disassemble the unit take out the coin, reassemble it and put it back. Total cost is $265. (initial diagnostic cost is $120+145 for the dvd player work). Argh ...... still waiting for them to call me to pick up the car.
You have change in the front dvd player in the console shorting out the circuit.
You have coins getting in the dvd player causing the short. Have fixed three now. Remove dvd player. Open, empty coins out and your good.
Acura604
20
08-05-2017 12:55 AM
xsilverhawkx
09-28-2015 06:51 PM
ripit
09-26-2015 06:19 PM
