MDX 05 ...changing passenger side Engine Mount
Hi all.
There is a metallic clunking sound on my 127K MDX. I'm just sure it must be an engine mount.
Question. I'll be doing it myself. Do I need to jack the engine or is it ok to do it without it? Im concerned that it could drop once I remove the engine mount, but perhaps the other two will keep it in place.
Thanks!
Thanks!
the side mount is on the passenger side and EASILY visible.
you will be able to tell if its broken.
please, check or confirm that it is broken before you dive into the install.
also, if the front and rear mount are shot, it will not hold the engine up, when you're trying to replace the side mount.
if you do need to jack up the engine, use a jack and a piece of wooden block and lift at oil pan.
funny story, so i replaced my timing belt in my 2006 Acura TL.
however, i Must have damaged a seal and now the car is leaking oil.
last weekend, i went in and decided to perform more surgery on her.
I got my ratchet stuck in-between the frame and a pulley.
now, I have to un-do the front and rear mount to see if the engine has enough play so that I can get my ratchet out!
![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
justnspace (11-19-2014)
![](https://cimg6.ibsrv.net/gimg/acurazine.com-vbulletin/1120x2000/imag4890_25a7866bbf282b032019884fb1945f7f05d97841.jpg)
Yeap, it was pretty bad. The inner element was floating completely. What a POS material!
Anyway, if you decide to do yourself:
-need a jack and a wood block to lift the engine slightly to relieve load on mount
-need impact gun with 12" extension
-you will need to loosen the fwd electric fuse box to get access to the top mount bolt
All in all, pretty easy.
justin7779
12-25-2015 10:33 PM
sockr1
10-01-2015 01:31 AM
