Edmonton Acuraziner's
Old Nov 29, 2013 | 12:18 PM
  #4841
Siidhu's Avatar
New Member
Ill check em out, thanks
Old Nov 29, 2013 | 05:09 PM
  #4842
v|nsan|ty's Avatar
For the resistor I went with 0.22ohm instead of 0.12ohm since I have switchbacks up front and rear led turn signals in my tail lights. If you're planning to only go with switchbacks up front, then 0.12ohm will be sufficient.
You guys should do the zkw-r lens swap. Makes the cutoff from the headlights sharper and improves clarity of light output.
Old Nov 29, 2013 | 08:23 PM
  #4843
Sejanus's Avatar
7th Gear
I have a friend at Visions that can do a remote starter install for less than what you would be charged normally.
I got a Viper 2-way for my car, $500 cash. Normally over $800 for MT.
Old Nov 29, 2013 | 09:19 PM
  #4844
Jriddle8's Avatar
You guys should do the zkw-r lens swap. Makes the cutoff from the headlig sharper and improves clarity of light output.
So you know how to install these switch backs? If I happen to run into any snags would some one mind helping?
Old Nov 30, 2013 | 01:30 AM
  #4845
EdmTSX's Avatar
04 NBP 6MT TSX
Spotted Aaron in Chinatown probably having pho today lol
Old Nov 30, 2013 | 01:23 PM
  #4846
v|nsan|ty's Avatar
I doubt you'll have any troubles with the switchback install itself. It's literally twist the stock bulb out and put the new one in. Accessed by pulling the liner back from the fender partially and reaching in behind the headlight. The harder part is locating the module where you need to swap resistors. I had Myron do it for me since I couldn't find the part.
Old Nov 30, 2013 | 06:01 PM
  #4847
Siidhu's Avatar
New Member
anyone know the guy with the sexxy black TL i think his username is shift_ , just wanna know what kind of wheels he has
Old Nov 30, 2013 | 08:35 PM
  #4848
you8myrice's Avatar
xxr 530 i believe
Old Nov 30, 2013 | 10:24 PM
  #4849
Siidhu's Avatar
New Member
Those are the ones, thanks a lot man
Old Dec 1, 2013 | 12:15 PM
  #4850
Siidhu's Avatar
New Member
Anyone here work at future shop or visions, looking to get a deal on a escort 9500xi or
Beltronics RX 65, and I want it in red led to match my interior lighting
Old Dec 1, 2013 | 12:24 PM
  #4851
you8myrice's Avatar
$430 right now at visions
http://www.visions.ca/catalogue/cate...&sku=9500IXRED
Old Dec 1, 2013 | 01:54 PM
  #4852
Siidhu's Avatar
New Member
That's a really good deal, thanks alot
Old Dec 2, 2013 | 09:25 PM
  #4853
Sejanus's Avatar
7th Gear
So my car broke down this weekend. Was in a McDonald's drive thru when it happened, had to get pushed out. Some kind of issue with the clutch assembly and my 3rd gear syncro is also shot. Apparently that's a 13 hour job. The funny part is they didn't have a courtesy car available until Friday. After they found out the cost to me, they made a vehicle available to me tonight lol.
An easy $3200. Yay, just in time for Christmas!
Old Dec 2, 2013 | 09:42 PM
  #4854
Jriddle8's Avatar
Wow, that sucks man. What car do you have?
Old Dec 2, 2013 | 10:28 PM
  #4855
Sejanus's Avatar
7th Gear
2008 TL-S 6MT ASM
Only mods so far are ATLP cat-back with an XLR8 metal cat and an AEM V2 CAI.
It does suck, but they loaned me a 2012 TL. It shall be fun to play with
Old Dec 3, 2013 | 12:06 AM
  #4856
ArenHam's Avatar
TL Owner
2008 TL-S 6MT ASM
That sucks bud, hope it gets fixed quick! I might upgrade to the 4gen TL next year, that SH-AWD would come mighty helpful in this shitty weather...
Old Dec 3, 2013 | 09:37 AM
  #4857
myron's Avatar
Ouch that sucks man. how many km? I am guessing you never changed your tranny fluid with the GM syncronomesh stuff. I had a 3rd gear pop out problem on my car at 92000km. They said I need new tranny, and gave me some ridiculous $ amount. Changed it with that stuff, and I drove it for 65000km more without a single issue. I would look into it in the future especially if you drive the car hard.
Old Dec 3, 2013 | 04:16 PM
  #4858
Sejanus's Avatar
7th Gear
No, but I have had the transmission fluid changed before. In addition Honda apparety changed what they were using in the tranny. I'm close to 160k on the car, but I definitely had some issues before. I even brought it in to Acura and they could never replicate the issue. So they leave it at that.
Luckily I have the money in the bank, so it's not that big of an issue for me. Some of the work they are doing is an eventuality. Better now than never!
Old Dec 3, 2013 | 04:19 PM
  #4859
Jriddle8's Avatar
wow 160k, i only just hit 90k on my Tl-S.
I know its a newb question but how often do you guys recomend to do the transmission fluid? My last car was a beat up civic that i only changed the oil on...
Old Dec 3, 2013 | 05:27 PM
  #4860
myron's Avatar
yea I had the same issue, I went to Honda at 92000km, still having warranty on the car to look at the 3rd gear. They said they could replicate it, but they couldn't confirm if the previous owner did a tranny fluid change at 60 000km as required apparently so they voided my warranty and said they can change it for 3000$. They changed the fluid and a week later I had a 3rd gear popping out again. Got the GM fluid and that was the end of that problem. And honda didn't change anything in that fluid, it's bullshit man.
Funny thing is, when I walked into a GM dealership and asked for Syncronomesh Friction modified tranny fluid, guy knew I drove a honda haha
Old Dec 4, 2013 | 09:00 AM
  #4861
EDMGenerTL's Avatar
5th Gear
What is the cost to replace the fluid?
Is it an easy swap?
I drive a base TL 6spd , and wondering if this will make shifts smoother as well.
Old Dec 4, 2013 | 02:52 PM
  #4862
myron's Avatar
Is it an easy swap?
I did it myself, it's pretty much as easy as changing the oil. It will be MUCH MUCH smoother shifting.
I believe it's made by ACDELCO now and it should still say Friction Modified on the bottle.
just one of the threads I seen, there is many more on this
https://acurazine.com/forums/3g-tl-2004-2008-93/gm-synchromesh-availability-alternative-803374/
Old Dec 5, 2013 | 08:17 AM
  #4863
EDMGenerTL's Avatar
5th Gear
https://acurazine.com/forums/showthread.php?t=803374
Thanks a bunch Myron.
that was very helpful.
seems that ACDelco relabels theirs, which is exactly the same as the GM fluid.
They just slap a ACDelco sticker over the GM bottle.haha.
according to the diy link, its only a 1/2 hour job.
I will be looking into this for sure!
Thanks all
Old Dec 5, 2013 | 11:36 AM
  #4864
myron's Avatar
Thanks all
yea AC Delco bought that stuff out, never messed with a formula, just put a new sticker on it and that's it. I swear by this stuff, I used it and it helped. I sold the TL 3 years ago almost and they guy is still driving it with no issues.
Old Dec 6, 2013 | 09:46 AM
  #4865
Sejanus's Avatar
7th Gear
I think your manual suggests when to change your transmission fluid as well.
Myron, I certainly believe you and was going to switch over, but the issues I was having kinda disappeared for awhile. Would you suggest doing a 3x3 since you're swapping fluids or just do a drain and fill?
Jriddle - I've had my car since it was brand new, lived in fort Mac for 2 years. Put 50k on it easy in 1.
So I picked my car up Wednesday night, talk about getting parts fast and getting her done. They claimed the rear main seal was leaking and managed to get a lot of the work covered under warranty. I only ended up paying for the clutch assembly - $730 out of my pocket. My clutch engages a lot closer to the floor, and I'm pretty sure that's what it was like brand new!
Old Dec 6, 2013 | 10:31 AM
  #4866
myron's Avatar
I am not sure on the 3x3, I didn't do it that way. All I did was drain, refill, drive. I think 3x3 is for the automatics, but I am not sure. In all honesty, it wouldn't hurt at all if you do it that way for peace of mind. you pay a little extra but you don't have to do it often so who cares.
And that's great that you only had to pay 730$, pretty lucky.
Old Dec 9, 2013 | 06:27 PM
  #4867
Siidhu's Avatar
New Member
So myrooon I got my LEDs for the side markers , you think you will be free sometime this week ?
Old Dec 10, 2013 | 09:08 PM
  #4868
Jriddle8's Avatar
Hey guys, so the temperature seems to be dropping and with me being lazy and cold waiting for my car to warm up. Does anyone know where i can get a good clean install for a starter? as well any recomendations on starters?
I previously had starter on my civic but Visions installation i found to be unclean.
Old Dec 11, 2013 | 06:36 AM
  #4869
Sejanus's Avatar
7th Gear
I could PM you a friends number. He works at Visions but is quite experienced and does the work under the table. So you save money. Cash only obviously. Let me know if you're interested.
Old Dec 11, 2013 | 09:30 AM
  #4870
myron's Avatar
forum member JBOND works at visions, installed one a few years ago on my TL and 2 days ago installed one on my FX, never had a problem. Great guy and good installer
PM him and I will shoot him a text as well to tell him you PM'd him so you guys can figure it out.
Old Dec 11, 2013 | 09:31 AM
  #4871
Jriddle8's Avatar
Great thanks Myron I'll PM him.
Any recommendations on starters?
Old Dec 11, 2013 | 09:33 AM
  #4872
myron's Avatar
sorry man, I won't be able to do anything in the next few weeks. I am spending my weekends in a German language class, and week days won't work for me due to work training on new software. So until Christmas I am busy, and during Christmas Holidays, lets face it, I will be drunk. But I will keep you posted if anything changes
Old Dec 11, 2013 | 09:34 AM
  #4873
Siidhu's Avatar
New Member
Lool it's all good man, just take your time I'll talk to you soon
Old Dec 12, 2013 | 12:06 PM
  #4874
Dean O 1965's Avatar
Sherwood Park Member - Second Gen RL
Hello All,
Just got my first Acura a few months ago. It's an 05 RL with 154,000 km so I have been fixing several little things and getting this car back to where I want it. I would love to find a good, reasonable mechanic if you have any advice. I have a clunk in the front end that sounds like a loose suspension part or something. Had it checked out at Wilson Auto Tech and they don't know what it is.
Merry Christmas
Old Dec 12, 2013 | 01:11 PM
  #4875
Sejanus's Avatar
7th Gear
Probably just a bushing between the strut and coil that is worn.
Old Dec 12, 2013 | 01:55 PM
  #4876
myron's Avatar
Originally Posted by Dean O 1965
Hello All,
Merry Christmas
get some coilovers and that slam the car, that might fix the problem. It could also be the front sway bar end link. I know that I mine was making a clunking noise as well when it went.
Old Dec 13, 2013 | 12:49 AM
  #4877
ArenHam's Avatar
TL Owner
Hello All,
Merry Christmas
Oh good luck, parts for the RL are very expensive due to the car being one of Acura's worst sold so take care of the RL while you have it.
Old Dec 16, 2013 | 07:41 PM
  #4878
you8myrice's Avatar
Old Dec 22, 2013 | 03:54 PM
  #4879
Faith07's Avatar
Hi everyone!
Does anyone know of any quality paint shops that wont try to destroy me on cost?
Old Dec 25, 2013 | 12:17 PM
  #4880
Siidhu's Avatar
New Member
Hey, anyone know how to remove the amber reflector from the headlight housing ?
