Zaino/Clay Bar
Zaino/Clay Bar
Okay, I got the clay bar and I'm going to try and do it when I get home today. But my question is....how well does the clay bar remove buggs? I went on a roadtrip this weekend to Florida and have a ton of bug splatter that I couldn't get off very well with just a car wash?
Originally posted by NSXNEXT
It works great. Use plenty of lube though. I suggest mixing up some Dawn and water to make the lube.
Dawn will strip ALL the wax off on the area you are “claying”.
Shawn S
I'll second Shawn on that. if you have zaino on the car - and you have Z7 wash - mix a cap or two in a spray bottle as the lube.
If you dont have Zaino on the car - dawn and clay will certainly remove al wax on the areas you do.
If you dont have Zaino on the car - but for some reason have zaino wash (???) use that mixed with water - then clay.
Sure, why would you NOT have Zaino on the car - but have a Zaino clay and wash ?
Just covering all the basics . . .
remember - dont clay in circles - very very light side to side motions - till the "click" isnt there - then move on. Keep it lubed, asd lay a twoel on the bround below the work area in case you drop the clay - if it hits the actual ground - toss it. if it hits the towel - ure ok, just turn it inside out and expose a new clean surface.
have fun . .
have fun . .
Dawn does not strip Zaino. Clay strips Zaino. Dawn just makes it squeaky clean.
The only thing I have found that strips Zaino is an abrasive, like 3M SMR or denatured alcohol.
Originally posted by Homer2
...lay a twoel on the bround below the work area in case you drop the clay - if it hits the actual ground - toss it. if it hits the towel - ure ok, just turn it inside out and expose a new clean surface.
have fun . .
have fun . .
And take your time when using the clay bar. GO SLOWLY. If you do quick back-and-forth motions, you'll see that clay bar fly out of your hand and into the petunia beds. The clay bar is the most-intensive and slowest part of the process, but you do end up with a real smooth finish.
ExcelerateRep
Sponsored Sales & Group Buys
Sep 22, 2015 10:39 AM
