Shaved my emblems
Shaved my emblems
I shaved my emblems off the back of my car yesterday, and it left pretty much the whole emblem letters behind it in sticky adhesive...I tried to pell it off, and scratch it off with my nails but it was just making a mess. What's the best stuff to use thats safe for the paint to remove this sticky stuff? I was going to use Goo-gone, but wasn't sure if there was a better choice for car paint?
thanks!
thanks!
Use a steamer, saturate the adhesive, and get a clean rag and wipe it off. Your neighbor might have one.
My first Avatar....
Goo gone is good. You also might want to try WD 40. It really breaks down glue and it won't hurt your paint. I'd stiil clean it well afterward and re-seal it.
My first Avatar....
Goo gone is good. You also might want to try WD 40. It really breaks down glue and it won't hurt your paint. I'd still clean it well afterward, and re-seal it.
My first Avatar....
wtf??? sorry for the double post. Azine is so slow sometimes. i might have hit the post button twice.
I did this yesterday, i used a hairdryer to heat up the leftover tape/sticky stuff, and used my fingernail to slowly peel it off. Took some patience, but i got it done pretty nicely. After that i washed the area with my normal car soap and water, as there is lots of fine dust left around where the letters were. Then for the left over bits of sticky, i just used some alcohol(99% is best, but any will work) on a cotton ball and rubbed the hell out of it. After that you could barely see where the letters were, there was a slight haze. Then i hit it up with a coat of wax, and it was gone, then i hit it with one more coat just for safe measure, i did just rub the paint with a whole bunch of alcohol anyways. Good luck!
Be careful not to use too strong of a cleaner or such an abrasive method to remove the residue. You don't want to create more work in the form of surface scratches that break the clear coat. I haven't debadged my TL, but I did my Maxima. I used a hairdryer to heat up the emblems. The residue I took slowly away in layers by using Griot's Garage Bug and Tar Remover and their Wheel Cleaner - all applied with a MF. Then, I clayed the area, used a good polish, paint cleaner and then sealed the area. Just go slow and be patient.
Originally Posted by redzjon31's
How does it look got any pics??
So as soon as I'm able to wash it, I'll remove the sticky, and post pics
i just did this last week also...i used a hair drier, dental floss, Goof Off and my finger nails....when the emblems are off, put some of the goof off on a towel or whatever, and saturate the glue. give it a second to absorb and then pick at it slowly...patience buddy, it'll turn out fine! i did it on my sundance gold cl-s and you cant see anything!
6th Gear
I just took mine off last week. Waited for the sun to heat up the car, dental flossed the letters off, peeled most of the sticky residue very carefully by hand and used goo be gone for the little that was left. There was a little bit of haze left over I tried soap and water which didn't work for me so I just went over it with some meguiar's scratch remover and it came right out.
"Advance"
Glue or sticky residu
The best way to remove all the glue or sticky residu on the paint without scratching it is probably the lighter fluid.
Put some lighter fluid on a soft towell and pass on the sticky areas, then you should see everything come off easily. Don't forget to wach your car after or only wach the area wich as some glue on.
Hope it helped you guys!
wow, so many methods...I did this yesterday to my ACURA and TSX emblems. First of all, I poured hot water to take off the emblems so the residue left behind was still damp. I just used my finger to rub the large chunks of tape off. You have to rub hard but it comes off. Once I got the majority of it off, I took rubbing alcohol to clean off the rest. I followed up with Meguires Scratch X and it looks super clean. HTH.
here's mine debadged. i used fishing line to remove the letters, then just used my fingers to remove the sticky stuff off the car. then i just used a polish to remove any residue that was left.
if anyone knows how to post pictures from a cell phone let me know, i can go out there and snap a good one now and send it to who ever knows what he/she's doin...b/c i dont! ha
that TL looks hott, think bout tintin the tail lights?
yeah, b/c it would look hottt all blacked out back there...i know a bunch of us 2nd gen CLers either have/ordered Rockblocker tail/headlight tints, have you looked into it?
it's a sticky film...fom what i hear, lots of members have best results with that...if you do a search for rockblocker you'll prob come up w/ their website or somethin...ill try lookin for you too and post when im done doin some shit at work
found it...
https://rbaftermarket.com/catalog/in...36b519a945eb95
this stuff isn't cheap. i've bought 2 regular tint kits off ebay, for like $18 each. i wonder what the quality difference is between the two. the kits i got off ebay were pre-cut template tail light tint films. but they werent made out of the same material as traditional tint. i dont know how to describe the film i got off ebay, compared to regular window tint, but it was definitely different from regular window tint. plus, i messed both of those up (got really big bubbles & shit) so i dont know if i want to spend $60+ on another tint kit.
2000 Acura TL
sorry bout the pic quality but right now this is all i have of the rear. All i did was poor some boiling hot water on the emblems, used some floss, and then used goo gone for the extra tape left over, yes there is a very very minimal amount of haze/tape left that cant be seen from the untrained eye, but it goes away over time. I think im def gonna try some meguires scratch x, got some of that laying around somewhere
EvilVirus
12-10-2015 07:38 PM
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
