Prepping to use 303
Originally Posted by greydh
Is there any prepping that needs to be done to the vinyl/plastic BEFORE using 303?
If so, what needs to be done?
Former Sponsor
If you have had previously applied a protectant, your going to want to make sure you have removed any oils. Just use a all purpose cleaner diluted properly for your task. The apply 301 per instructions. Its not like your applying a sealant or wax, but just make sure your surface is cleaned.
Former Sponsor
Anything literally. Just read the proper dilution ratios and then add a little more water, or a little less APC. You dont want it too strong. Mr. Clean, Lysol, 409....literally any all purpose cleaner will work. If you can smell the product in the water, its too much...Thats my rule of thumb for general cleaning. Use warm water, drop your microfiber in the bucket, squeeze out excess, and wipe away, repeat. Wipe dry with a clean microfiber towel....wallah...Ready for 303.....Fold MF several times to accomodate size, spray MF with 303 several times, away from surface, wipe, repeat. Wipe with dry/clean MF....done.
never stops!
Originally Posted by d-rock
i use 5:1 water:woolite mixture; works well
I use water woolite and the clean the surface, wipe with dry towel, spray 303 on another towel and apply evenly. No buffing is necessary.
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
