porter cable orbital _____
is a porter cable orbital sander the same thing as the porter cable random orbital? just different pads on the end?
are these the same machine?
http://www.griotsgarage.com/catalog....1004&SKU=10625
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
teh Senior Instigator
identical
there are two different model #'s actually, they are just different counterweights which doesn't make a difference.
Originally Posted by aspar
is there a diff between the 7336 and 7424???
7424 = 6" plate w/ 5" counterweight (for use with included lightweight 6" foam polishing pad)
7336 = 6" plate w/ 6" counterweight
I think I will be picking up the 7336 from Lowes
Constant Pressure (LC) 6-inch Foam Pad Starter Kit:
A constant pressure foam pad, this is essentially a flat 6-inch pad which uses a patented technology layer of engineered, instant rebound foam between the pad and the backing plate to absorb off-axis movements while keeping the pressure of the pad on the surface constant. These European pads are made from engineered, thermally reticulated (exploded open cell) foams with a 99% open cell structure, specifically designed for compounding, polishing and finishing. Blue "Constant Pressure" foam backing absorbs any unwanted ‘off-axis’ polishing motions (ideal for the inexperienced user)
Constant Pressure Foam Pad Starter Kit:
•1-Polish / Cutting Pad (*Yellow)
•2-Polish / Light Cutting Pad (*Orange)
•2-Polish / Waxing Pad (*White)
•2-Finishing Pad (*Black)
•1-5-inch Flexible Urethane Backing Plate
*The foam pad colour identifications and specifications are by Lake County Manufacturing (LC) www.lakecountrymfg.com other manufactures of foam pads use a different colour to identify the abrasiveness or cutting ability of their foam pads, they can be purchased at www.properautocare.com.
JonM
JonM
... Blue "Constant Pressure" foam backing absorbs any unwanted ‘off-axis’ polishing motions (ideal for the inexperienced user) ...
)I went with pads from exceldetail .. great prices, good quality, quick shipping, and supporting another Acurazine member is always good form!
cycdaniel
Dec 17, 2019 10:58 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
