Moisture
Old Mar 7, 2009 | 02:04 AM
nf3d0149ab's Avatar
Question Moisture
I've got some moisture in my trunk...it's bothering me A LOT!!!
I am going to take it into the body shop next week because I think the trunk needs to be re-sealed with Silicon.
Any products I can use to dry up and remove the moisture in the trunk?
I was thinking something I saw @ Target that you would put in your house that "DampX" or something like that.
Can't remember specifically what it is but I would like to dry it up before any mold or mildew takes effect.
Please...any ideas or experience you can share would be greatly appreciated.
Would like to get on this ASAP!
Thanks in advance.
Noah
Old Mar 8, 2009 | 03:44 PM
nf3d0149ab's Avatar
Nobody has any ideas?
Any products that are good at pulling moisture out of the interior?
I've put towels everywhere and I keep changing them because they are wet.
Old Mar 8, 2009 | 04:21 PM
csmeance's Avatar
try maybe baking soda pouches and silica gel packets also leave your trunk open to air dry a bit too. I'd take out the liners and stuff and let them try in the sun, then spray them with lysol or something to keep mold from growing on it.
Old Mar 8, 2009 | 04:55 PM
jaysizzlecity's Avatar
B A N N E D
Rip out everything from the trunk and let dry..... Or the back window is not sealed fully..
Old Mar 8, 2009 | 05:28 PM
exceldetail's Avatar
Former Sponsor
Ive used "Damp Rid" with great success. Pulled moisture right out of drywall!!
Old Mar 8, 2009 | 11:16 PM
nf3d0149ab's Avatar
What would silica gel packets do?
Probably something I would have to order online...never seen them in person at a store.
Those are the little packets you see in shoe boxes or stuff like that...?
Also...Lysol spray?
I can only think of the Lysol Air Freshner Spray.
Is that what you were referring to?
That's exactly what I discovered is happening.
Spoke with some of my local Azine buddies and they mentioned that they would have to probably pop my rear window out to re-seal it.
Thanks.
Also...I have a tiny spot in the edge of the trunk where the water is seaping in.
Hope it isn't too expensive to repair...doesn't sound like it would be but it's definitely an issue that needs to be addressed ASAP!!!
That's exactly the product I was thinking of...just couldn't remember the name.
Sounds like it works then.
Thanks.
Old Mar 9, 2009 | 04:16 PM
EliteDemon's Avatar
The TARDIS is my
your trunk edge problem should be easy to fix noah, if it's on the sill; dry it and throw a tiny bit of bondo on there.
if you mean it's seeping through the opening between the main body and the trunklid; a little bead of silicone sealant would fix you up, just make sure to wipe it a little thinner if you use a sealer gun. AND DON'T CLOSE THE LID UNTIL IT'S DRY! glueing your trunk shut is not recommended.
Old Mar 9, 2009 | 09:22 PM
intensity2x's Avatar
Yes, thats what it is. Keeps the moisture out of new shoes and various other things. Obviously, you would need more than a little shoe box packet It's called desecant (sp?), check the paint aisle at Home Cheapo. Def get the leak fixed asap too.
Old Mar 9, 2009 | 09:52 PM
Omar650's Avatar
i had a leak right under neath my tail light i sealed it up with some caulking.
Old Mar 10, 2009 | 01:01 AM
nf3d0149ab's Avatar
Yeah...just got to do a little more research on it.
Not familiar with using the stuff but sounds easy enough.
I'll look into it the next time I visit that place.
Thanks for the info.
Those leaks can be sneaky lil bastards!
Old Mar 10, 2009 | 01:03 AM
combat mediC's Avatar
Noah. All you need is *shamwow*
Old Mar 10, 2009 | 01:04 AM
nf3d0149ab's Avatar
Bought some Damp Rid today that hangs on a hook.
Hopefully that will work out good.
It can rest on the hooks for the cargo net.
Old Mar 10, 2009 | 01:05 AM
nf3d0149ab's Avatar
Or just stuff that dude into my trunk...shabam!
Old Mar 10, 2009 | 07:19 AM
Former Sponsor
Dont let it spill over.........
Old Mar 11, 2009 | 01:28 AM
EliteDemon's Avatar
The TARDIS is my
If it weren't a 20 hour drive with three border crossings I'd love to help... but you know... it is...
Old Mar 11, 2009 | 01:42 AM
nf3d0149ab's Avatar
Thanks man for the offer anyways.
Old Mar 11, 2009 | 01:50 AM
EliteDemon's Avatar
The TARDIS is my
No Problem... empty unrealistic promises are my specialty...
wait...
Old Mar 13, 2009 | 01:46 AM
nf3d0149ab's Avatar
Originally Posted by elitedemon
no problem... Empty unrealistic promises are my specialty...
wait...
lmao...
BigJilm
Sep 21, 2015 08:32 PM
max4swag
Sep 14, 2015 07:55 AM
TOGWT
Wash & Wax
Feb 8, 2008 03:50 PM
