Light fading of the dash, what product to hide this?
On my '04 TL with black interior, the dashboard is fading in small splotchy sections and it looks like it could use some reconditioning.
What does everyone else use product wise on their dash to prevent or hide this fading? Very wary of off the shelf products such as armor-all...
I've heard that 303 Aerospace Protectant is pretty good but not sure if anyone has first had experience with anything else to remove this fading, if its even possible.
i don't think there's anything that's going to permanently bring back the dash to it's original condition. Right now you've got to protect it so it doesn't get any worse. I've had success with the 303. I believe it's uv 40 so it will help with that and it also brings out a really nice look. i use it for all rubber plastic, inside and out, on my tl
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
303 is probably your pest bet from a treatment perspective, but like others said, it's not giong to make the fading go away
the problem is that it's not fading, but a chemical that is migrating to the surface causing the milky looking surface. The only way to cure it is to clean off the surface and apply some protectant.
I used the woolite solution and then followed up with plain water, then 303 aerospace protectant
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
Soul_Deamon
4G TL Problems & Fixes
11-02-2015 04:32 PM
wusty23jd
09-24-2015 11:41 AM
