Leather Seats cracking?
Old Sep 28, 2004 | 08:24 AM
quigley0's Avatar
3rd Gear
I have about 900 miles on my TSX, and i've noticed that the drivers seat is starting to get "creases". Now, i am a big guy, and the seats have to endure a lot. Is this normal, or do I have to worry about the seat cracking? What can I do to prevent this? Is there a leather "treatment" that I can buy?
Old Sep 28, 2004 | 12:49 PM
landerso's Avatar
quigley0,
This is normal, and is one way to tell leather from vinyl. As long as you periodically clean and treat the leather with a product like Lexol, it shouldn't progress into an actual crack. That occurs when the leather is allowed to dry out, which leather conditioner will prevent. Before you condition it you should clean stained areas with an appropriate product besides saddle soap. Saddle soap leaves a residue. Also, if you have the parchment or quartz leather it will eventually stain from the dyes in your clothes unless you clean it. The whole process of cleaning and conditioning isn't hard as long as you do it regularly.
Old Oct 1, 2004 | 08:08 AM
ResidualFreedom's Avatar
2400 Watts in a TL...Why?
Try to look at your leather like your skin. It needs periodic cleaning and moisturizing. My personal favorite, as well as many other people, is Lexol. They make a cleaner, like soap, spray on the cleaner and wipe it away with a damp cloth or microfiber towel. The Lexol Conditioner I try to use at least once a month, it makes the seats soooo soft, and it helps the leather retain it's moisture, thus preventing cracking and some folds in the leather. I find the back seats don't need it as much as the front do simply because of less wear (I don't usua;;y have people in the back) and lower ammount of sunlight ( I would assume the front seats get more throught he windshield).
hope that Helped,
Patrick
Old Oct 3, 2004 | 03:20 AM
quigley0's Avatar
3rd Gear
THanks
Thanks guys. I'm gonna run out and get some Lexol!
FYI: Just crossed the 1000mi mark this week!
Old Oct 5, 2004 | 03:51 AM
ianz's Avatar
is it ok if i just use armor all?
Old Oct 5, 2004 | 07:18 AM
landerso's Avatar
NOOOOOOOOOOOOOOOOOOOOOOOOOOO!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!
Armor All is ok (some will argue with me) for vinyl, but it is death to leather. Trust us - use a leather product like Lexol. It's easy and it works.
Old Oct 5, 2004 | 05:48 PM
ianz's Avatar
oh ok! thanks for the tip!
how often should i use lexol?
and should i just use a cloth and water for normal cleaning?
Old Oct 5, 2004 | 07:01 PM
johnstelting's Avatar
Take it back to dealer
Mine and other's on this group have noticed the same thing happening. I took mine in and the dealer is replacing the bottom portion of my drivers seat.
Old Oct 6, 2004 | 07:20 AM
landerso's Avatar
ianz,
I've heard that some folks use Lexol monthly. I do it quarterly, but things tend not to dry out down here (Charleston, SC) - instead they mildew :-). Use it on the high wear areas whenever you do a thorough cleaning of the interior. It take only a little more time than something like Armor All.
Old Oct 7, 2004 | 01:57 AM
ianz's Avatar
Thanks landerso!
i better go look for some lexol at canadian tire or something.
so for weekly cleaning and stuff, i can just use a soft cloth and a little water?
Old Oct 7, 2004 | 03:45 AM
KingV's Avatar
Originally Posted by ianz
Thanks landerso!
Zaino makes some decent leather products as well, I personally use them. I like them because the conditioner has a very nice leather smell that keeps the car smelling new. I've never used Lexol myself, but my father swears by it, I've heard it leaves more of a shine to it, whereas the Zaino does not really. I dress with 303 on top of the Zaino protectant to add shine, however.
Old Oct 7, 2004 | 05:38 PM
landerso's Avatar
ianz,
All you need are a couple of clean cloths, one of which needs to be damp. The instructions are simple and the results are worth it. I've never noticed a shine from Lexol, but I know KingV is a Zaino fanatic (Hi, Tom :-).
Old Oct 8, 2004 | 03:25 AM
ianz's Avatar
haha cool
thanks guys
Old Oct 8, 2004 | 09:37 AM
KingV's Avatar
Originally Posted by landerso
ianz,
I wouldn't say I'm a fanatic. I mean, I do have SOME other products in my line-up, like uhhh, the Porter Cable buffer?
Old Oct 11, 2004 | 11:51 PM
gt0279a's Avatar
quigley0,
Saddle soap is ok to use, but it's really only needed if the leather is very dirty, old or dry.
Saddle soap is designed for use on harshly treated leathers that are outside 24/7, making it useful in convertables and old, dry leather. Lexol and other products don't have the punch to rejuvinate like saddle soap does.
When leather ages, it looses its finishing compounds that protect it from drying out and fading. The residue you speak of is the finishing compounds in the soap. Leaving this on is more practical on a horses saddle or leather work boots.
The trick to using the saddle soap is wipe the area first with a damp cloth, apply the soap on a cloth, rub it in and let it penetrate for a few second and then wipe off the excess.
Again, I wouldn't use it a a regular method of cleaning, but's it is great for tough jobs.
Old Oct 12, 2004 | 11:56 AM
blackjackman's Avatar
what part of the seat ?
the left-side bolster or the middle area ?
I am guessing you're talking about the side-bolster.
It creases every single time getting in the car you move your butt over it. Creases more if you rub over with your full weight.
I've gotten used to lifting myself OVER the bolster when getting in.
On a side-note and this may open up another flood of guesses/debates:
Isn't the side bolster NOT leather but vinyl ?
Is it OK top use leather conditioners on vinyl ? like the dash, door panel...?
Old Oct 12, 2004 | 01:49 PM
STL's Avatar
STL
There is no debate, the top of the side bolster is leather while the side vinyl. It's just than some people around here have been propogating bad info.
Old Oct 12, 2004 | 02:18 PM
I'd love to go in peace believing it's genuine leather.
Just not sure, still confused - too many opinions out there you know ?
If you have come across references to CONCRETE proof or some kind of "official" statement, please provide.
Old Oct 12, 2004 | 03:09 PM
fdl's Avatar
fdl
Proof? We dont need any proof - STL just told us the way it is. Didnt you read what he said, there is NO debate.
Old Oct 12, 2004 | 03:35 PM
STL's Avatar
STL
If you want CONCRETE proof, then you should take it to a leather shop and just ask them. By running a finger across the surface (with moderate pressure), I can easily feel the difference between the vinyl and leather. Both the perforated sections and the tops of the side bolsters feel the same, whereas the sides of the bolsters feel thinner and more flexible. Others here (and on other boards) have also offered similar feel tests. Furthermore, the very creases being talked about in the original post of this thread is typical with real other -- and not with vinyl.
FDL read an Acura press release than mentions perforated leather and mistakeningly delcared only the perforated sections are real leather.
Old Oct 12, 2004 | 03:50 PM
fdl's Avatar
fdl
Actually, someone did take it to a leather shop...
Originally Posted by sauceman
While going to my friends' shop, where they repair shoes and also work with leather in general, I had to show him the interior of the car for him to know what kind of leather to use to fabricate a small cushion to add height to my center armrest. The car being clean, I want to have something that matches well.
When he sees the interior, he says, "Well we don't have this here, it's leatherette (translated from French "cuirette"). I says, " What do you mean?", and he answered, "It's fake leather".
And part of my world of ilusions came crashing down. Is that true? If so, why do they call it leather if it's not genuine?:'(
And I'm still not saying you are wrong, in fact I hope you are right (although its not that big of a deal). There just hasnt been any definitive information.
I am going by what a bunch of people told me from over a year ago back on the old site (I tried to find the thread but the old site is gone completely)
Old Oct 12, 2004 | 04:03 PM
I read that thread about the leather shop.
You can place all your trust in what THAT leather shop said and it ends there - for you and those who choose to accept it.
There's been way too much opinions based on feeling this & that and guessing.
Final verdict - for anal me personally - is someone knowledgeable looks at a tiny sample under microscope - the scientific way. No ifs, ands, nuts, guesses, feelings, opinions.
Old Oct 12, 2004 | 04:11 PM
STL's Avatar
STL
And here is a later post from that very thread:
Originally Posted by CDR
Updating an old but potentially important thread ...
I had a vinyl/leather/plastic interior magician work on my TSX dashboard today to repair screwdriver marks the dealer tech had put into the console area while replacing the audio unit for the "console lights out" problem. (Amazing -- looked like new when he finished.)
When he was done he was giving me interior care advice -- and the BIG surprise was his assertion that virtually all of the "facings" in the seats are real leather, not just the perforated center sections.
In his opinion and detailed inspection -- with his 25 years of experience repairing vinyl and leather in cars -- not only are the center perforated sections leather, but also the seat and side bolster facings, all of the front headrest material, and the main facings of the rear seat. The rear headrests are part leather, and the top of the console cover is real leather. The backs and skirts of the seats are vinyl, as are the inserts in the doors.
I know this is different from the accepted wisdom on the board -- which I accepted. Because I was skeptical, he carefully went through each part of the seats and showed me why each part was "real" or vinyl, like the way it pulls and gives, the texture patterns and variations, etc. He even looked inside thread holes to see whether there was leather or fabric inside. He works on new-ish cars for dealers (when they botch something!), so he has plenty of current experience on all makes, common and luxury, and it seems unlikely he would be fooled by even the latest vinyl.
For me, the implication is how I take care of the "previously vinyl -- now believed to be leather" sections -- I'm getting out the Lexol!
Old Oct 12, 2004 | 04:16 PM
STL's Avatar
STL
blackjackman,
Being the engineer that I am, I thought I was anal -- but you take the cake! Seriously dude, just run your fingers across all the different surfaces!! Take a little time to investigate it yourself, and you will see that easily feel/see the difference between vinyl and leather. I think you are just getting confused reading the old stuff. The consensus was that the facings are leather and the sides are vinyl.
Old Oct 12, 2004 | 04:22 PM
STL's Avatar
STL
Here are a couple threads:
https://acurazine.com/forums/showthread.php?t=1968
https://acurazine.com/forums/showthread.php?t=15212
Note the first one is the older one that both fdl and I quoted already. Here are a couple quotes from the later one:
Originally Posted by MarkPinTx
Not to pick a bone fdl, but I think the consensus eventually did emerge that all the upper (butt and back touching) parts of the seat are leather.
The "wear lines" that you refer to, I assume, are wrinkle-looking things. I bet a decent cleaning would make them go away. Just conditioning wont help. Need lexol cleaner (or some cleaner) or 6:1 water:woolite.
Good luck.
and
Originally Posted by blb
The entire seating surface is leather, as are the seat sides facing outward. The sides of the seats facing the console are vinyl. You can see and feel the contrast between the inner sides of the seats and the non-perforated leather seating surfaces sewn to the inner sides. Honda did exactly the same leather-vinyl split on the Pilot and on the last TL. At least on the TSX, the headrests are leather. On the Pilot, they are vinyl.
Old Oct 12, 2004 | 04:30 PM
that's fine STL.
Just one thing to chew on:
I am pretty certain Japan is the undisputed world leader in applying material science to the art of imitation and I am not talking about imitation crabmeat.
Japanese are the master at this for decades. If this were 1984 I'd believe what I feel. But this being 2004 I doubt the feeling test.
Old Oct 12, 2004 | 04:58 PM
STL's Avatar
STL
I understand where you are coming from, but you should take few minutes and try the feel test (or the pinch test like other have said). You should be able to at least confirm the material used on the sides of the bolster is different that what is used on the tops of the bolster. So unless you think Acura used actually used three different materials (two versions of vinyl and one leather) to make these seats then it fairly easily to deduce the fact the seats facing is leather. I highly doubt that they would use two different vinyls in the production of these seats because it would yield any cost savings. The fact the material used on the tops of the bolster looks and feels just like the perforated material (which is no one really disputes is leather because an Acura press release about the TSX menationed perforated leather) only reinforces my claim. Furthermore (and like many others have said) only real leather creases like people are seeing with the tops of the bolsters.
Old Oct 12, 2004 | 05:03 PM
STL's Avatar
STL
You might also want to re-read what I quoted from CDR. It sounds like he too was really skeptical until someone (who really knows leather and vinyl) took the time to show him the little differences.
Old Oct 12, 2004 | 05:05 PM
ClutchPerformer's Avatar
Good find. Something needs to be in the FAQ about this.... as soon as we decide who's right.
Old Oct 12, 2004 | 05:08 PM
STL's Avatar
STL
Like I could be wrong!
Old Oct 12, 2004 | 06:39 PM
Kanon23's Avatar
Gentlemen Racer
ok i feel mine starts having those "folds" too...believe it or not i have this car for almost a year and never got it done...should I be worried even if I do it now?
MrHeeltoe
20
Feb 23, 2023 01:54 PM
tsx_boy
Dec 13, 2019 08:33 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
hashbrown
Sep 29, 2015 12:13 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
